Home > Technical (L322) > 4.4 TDV8 - Front/Rear right doors wouldn´t lock/unlock...
shinchan
Spain
I had the following issues in the right side:
- Windows wouldn't close
- Doors wouldn't lock or unlock with remote or button in centre
- Mirror wouldn't fold
Ordered a second hand door module replacement with identical numbers on. Fitted it and now window goes up and down, but drives side rear door doesn't lock neither does drives door and the car beeps upon locking to say door is open. Replaced module with another one and still have the same issues, also change the left door latch and door module and no changes.
In the garage software (AUTEL) the replacement modules appear with the VIN of the donor car. Do the new (old) replacement modules need to be programmed to the car? If so how do I do this? Also I´ve a IID tool.
Thanks in advance
Post #724879 21st Sep 2025 12:37pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i have posted this befor, so hear it is again
hope it helps
i have had my RR 8 years and had locking problems for ever.
go to fill up with petrol and cant open the rear doors or the petrol cap.
R/H rear door window wont work properly.
less than a year ago i fitted a BCU out of a 2003 and every thing works fine RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #724897 22nd Sep 2025 6:25am
shinchan
Spain
Did you have to reprogram the BCU? Maybe BCU is damaged with the known problem of water ingress.
Now, I´m waiting for two second hand latches for front/rear right side that I bought to test...fingers crossed but I already start to search a second hand BCU...
Post #724951 22nd Sep 2025 9:43pm
knares
i dont know what model or year you car is.
mine is 2005
so it might be different
no, i did not need to program the BCU
i also used an earlier model BCU and it works fine
for some months i had no problems, then out of the blue, the remote wont open the drivers door, all the other doors work fine.
i changed the BCU with the proper one, but it made no difference.
i will have to fix that one day RR 2005 4.4 petrol
Post #724959 23rd Sep 2025 3:37am
knares
the BCU is under the passenger seat, should not have a water problem, i would think
easy to change RR 2005 4.4 petrol
Post #724960 23rd Sep 2025 3:40am
shinchan
Spain
mine is 2005
Mine a 4.4 TDV8 MY 11 LHD
Post #724973 23rd Sep 2025 12:21pm
shinchan
Spain
Post #725240 27th Sep 2025 8:21pm
