![]() | Home > Maintenance & Mods (L322) > Rear subframe replacement |
| Rudyard1 Member Since: 15 Nov 2021 Location: Devon Posts: 123
Also to add - does anybody know if the rear sub frame from a 2005 model will fit a 2007 model? 2007 Range Rover Vogue 3.6 TDV8 |
| AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 71
Looking at part numbers, seems there are 3, depending on your VIN number
Yes thats correct - have spoken with someone who refurbs these and states the only difference is the mounting bracket for the elec module. So same same, but different..... 2007 Range Rover Vogue 3.6 TDV8 |
| Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 147
Might be worth checking out Steve's Steel :
Thats the exact chap I reached out to for info - he currently is facing a 6 week lead time so I have had to try elsewhere. Shame really as his workmanship looks brilliant! 2007 Range Rover Vogue 3.6 TDV8 |
Well yes - my thinking also. 2011 L322 TDV8 A/b Orkney Grey
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
That would be your toe control arm rather then the anti roll bar drop link that became detached from looking at your picture.
Yes David you’re absolutely spot on - getting confused in all the trouble it’s been.
I am currently refurbishing a second hand sub frame and it is from an early model L322 - without EPB etc.
| All times are GMT |
