![]() | Home > General (L405) > Road testing 4.4 L405 |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
Get it over 3,000rpm Got - 2017 SDV8 Autobiography in Loire Blue
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
As above really. The 1st turbo works in the lower rev range, so it should be smooth for your normal driving and give you a moderate pull away.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
the second turbo kicks in at around 2500 rpm..at that point if theres any oil in the rear 'v' section of the engine where the oil cooler is then it will start smoking... ... - .- -.
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2776
For the record, the primary turbo is the bigger one and the secondary the fill-in. L405 D350 SE Carpathian Grey D5 19" rims |
