![]() | Home > Maintenance & Mods (L322) > egr blanking kit for td6 |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i wonder if this really does give you better performance and mpg..
| GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084
Give it a go Stan. Its only 40 quid |
i'm waiting for someone who 'knows' about egr and if its worth blanking or not...my engine is running very well at the moment and i dont want to upset it.. |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
i think my brother did something similar on his disco 3 and he said it was much better "RANGEISM WILL NOT BE TOLERATED"
| Rolo Member Since: 11 May 2011 Location: UK Posts: 852
There's a thread on rrsport about this http://www.rrsport.co.uk/forum/topic18862.html |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
My dad has done it to his TD6 Disco2 and is very pleased with the results. A bit smoother, and 1-2mpg extra. Not loads but worth it. He thought his throttle response was a bit better too. |
Are they easy to fit?
cheaper here peeps
all the advertisers claim improved mpg and performance so it must be true.. |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927
yes it is a well know fact that these things work, everyone was doing it on the Disco Owners Club, but as stated if you are going to do it i would do a proper job and make sure all the crud that it has fired back into the inlet manifold is cleaned out first. Current: TDV8 (3.6) RRS HSE
I'll be fitting one next time I'm down at my dads. Will make sure they clean out the inlet manifold as well and will report back on any changes in performance & economy. FFRR TD6 HSE
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Be worth cleaning out the inter-cooler while you're at it as well. |
Thanks for advice. I'll add it to the list. Let's hope it all makes a difference. FFRR TD6 HSE
| 993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58
Hi everyone, I would say egr are good am going to blank my rangie soon, I have done the egr blanking on my defender td5 I know it's a different vehicle but I had better throttle response and before I done it on defender I was getting 240 miles on full tank whereas now since I done egr I get 290 miles on full tank, best £40 I've spent on my defender which is my daily work horse. Incidentally when my rangie was on diagnostic the other week it showed a egr fault on the computer the same as what happened to defender which prompted me to do egr in first place.
