Home > In Car Electronics (L405) > End of 3G
Page 3 of 3 <123
Bill
Gremlin500 wrote:
I found this, which helped me a lot:
https://www.landrover.co.uk/ownership/inco...-faqs.html
Thanks for that… mind you I’m still confused…. Easily done Mildred.
Noticed this in the link . Some one said a little while ago if the phone was plugged in , then it uses the external car Ariel…. Anyone????? Those two fins have got to useful for something!!!!
I haven’t renewed wifi enabled , but kept connected & I haven't noticed anything yet.
Quote
What are the advantages of the vehicle's data connection over my smartphone's data connection?
The strength of your mobile phone signal and data connection can be significantly reduced by the structure of the vehicle – metal reduces the transmission of radio waves.
When inserted, the SIM card located in your vehicle’s interface panel connects to the mobile network via a significantly larger, dedicated aerial on the outside of the vehicle. This helps to maintain a much stronger data connection with the network.
Unquote. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #702669 20th Oct 2024 12:40pm
Gremlin500
@Bill:
Looking at “Lightning” on Wikipedia, the pinouts on the plug show only data in, data out, power and ground connections, so I don’t think the phone can use the aerial. Even if the car body has a partial Faraday effect, 5G is way better than 3G, which itself is 30x faster than 2G, so this far outweighs using a painfully slow 2G SIM in the car, better to simply connect the cars’ wi-fi to your phone hotspot, especially if you have unlimited data. May as well use something you are already paying for, than purchase inferior technology. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #702676 20th Oct 2024 1:11pm
Bill
Thanks…. Taken on board.
My iPhone X max phone is still 4g… I bought a number of excellent Apple cases as a job lot, working my way through the stock! …. Rolling with laughter
I will be getting the new iphone 5G enabled at the turn of the year as I’m expecting a much better signal whilst at home. Good reports from neighbours.
Ps
The difference tween an Apple case and a knock off from the internet is surprising / amazing. (some still for sale if anyone wants to buy new Apple iPhone X max case pm me. £25.00) Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Post #702699 20th Oct 2024 3:17pm
Spleen
United Kingdom 2017 Range Rover Vogue SE SDV8 Corris Grey
How are people getting on with this? I'm in no mans land with a 2017 car and noticed today that the 3G kept flitting in and out on a 250 mile journey. I'd forgotten all about the switch off so not quite sure what to do next. I have wired CarPlay and tried to hotspot the car to my iPhone 15 but it wouldn't have it, kept getting the circling squares.
Toyed with the idea of getting a dongle with a SIM but not even sure that will be effective. I have Waze on my phone so I know I can use that but I'd rather use the in car system just because. 3G is going, I get that but I'm mildly obsessive about this kind of thing and want it to work as its was designed without arsing about with hotspots, etc.
Sad 2017 Vogue SE
Ferrari F430 F1 Spider
Post #708870 11th Jan 2025 6:00pm
Markw
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
Mate I found that when hot spotting to my iPhone it would take ages to connect ok if I wanted to sit on drive for 5 mins and wait for it so I bought an lte 5g mifi unit from eBay £16 stuck a prepaid 3 sim that cost 65£ from amazon that gives 80gb a month till feb2027 it’s spot on
Post #708878 11th Jan 2025 7:22pm
Spleen
Yeah, I gave up after about a minute as I have the patience of a five year old - barely. Cheers for the info about the 5G jobber, does it work automatically when you get into the car or do you have to connect it? 2017 Vogue SE
Post #708922 12th Jan 2025 11:50am
Markw
Connects straight away usually I leave mine in centre console connected to usb cable so it charges when driving
As long as you switch off when not in use and switch on when you get in car it’s all ok
Post #708940 12th Jan 2025 2:49pm
Spleen
Nice one, cheers. I'll do that then. Out of interest, which one did you use off eBay? Amazon have them up for several hundred pounds but I can see some on eBay for £20ish. Just suspicious that one of them will have a dead mouse inside and nothing else. 2017 Vogue SE
Post #708941 12th Jan 2025 3:06pm
Spleen
Arch Stanton wrote:
so is it worth updating all of the in control options then? What wont work in future? Mine expire tomorrow.
Did you ever work what will continue to work and what won't? My subscription ends soon and I'm not seeing much point renewing it if half the functionality has disappeared. Just a bit concerned about the tracker and what effect, if any, with me not renewing subscription services and the 3G switch off will have. 2017 Vogue SE
Post #710463 28th Jan 2025 7:50pm
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
My car is now in Australia where there is no 3G and I can tell you from experience that there is no solution available from JLR. The remote services etc all rely on the internal telematics modem so all the incontrol pro functions that require a subscription no longer work. The only thing that I found useful were the map updates as you can download to a USB and get live traffic by using you mobile phone as a hotspot to the car.
I'm really disappointed as I like the remote locking/unlocking etc from my phone which now just say the car is in sleep mode.
I can't believe that there isn't legal requirement to at least maintain the SOS functionality 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #710465 28th Jan 2025 7:59pm
Spleen
Cheers, I'm guessing you've also lost the ability to track journeys, etc? I'm just unsure whether I should get an aftermarket tracker. 2017 Vogue SE
Post #710466 28th Jan 2025 8:03pm
Jase71
Personally I would get an aftermarket tracker 2017 Range Rover Vogue V6 Diesel
Post #710467 28th Jan 2025 8:05pm
Spleen
Aye looks that way. 2017 Vogue SE
Post #710469 28th Jan 2025 8:30pm
Jase71
Any updates on a solution to the end of 3G? One thing I liked using was the remote app but here in Australia the car is always in sleep mode with the lost connectivity Big Cry 2017 Range Rover Vogue V6 Diesel
Post #725027 24th Sep 2025 10:27am
Page 3 of 3 <123
