![]() | Home > General > Why do Range Rovers get such bad press for reliability? |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
Agree completely, it was the same with TVRs, they drift down the market as they age, to be purchased by folks who can’t really afford to run them, or pay attention to servicing pre-emptively, and probably have never even looked underneath a car.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 640 ![]() ![]() ![]() |
Sort of agree...but I also accept the evidence. In reviews/surveys JLR are less reliable than others. The cheapskates dont maintain these other marques either - but buy a Toyota and you'll most often get away with it.
It certainly does help that your car/s have been looked after properly of recent Mike. That and you have the budget available to keep them tip top does help sir... |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 787 ![]() ![]() |
JLR don't help themselves with things like the cracking front knuckle farce which should have been handled much better. The main dealers don't help, on more than 1 occasion I've had a warranty claim "rejected" by JLR which I subsequently found out hadn't even been submitted to JLR by the dealer.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
ive had 4 (2002/2004/2011/2016) in the last 16 years and none have been any trouble (save for inlet manifold cracking on 2011 TDV8). Other than that have always spent on upkeep and changed bits when told.
The surveys such as JD Power don’t really prove anything much because the results are much too generalised, in that they combine results across all the different manufacturers’ model ranges. I bet if you compared Range Rovers only against other luxury/upmarket vehicles with complex electronics, and also factored in the volume sold, there wouldn’t be that much difference, especially comparing older vehicles.
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 155 ![]() ![]() ![]() |
There is another reason that is easy to explain; in every forum, regardless of the vehicle brand, only the problems are written about, there are actually hardly any or no positive comments about the respective vehicles. This results in a picture of unreliability.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1011 ![]() ![]() ![]() |
Am on my fourth full fat Range Rover, my daily driver is a 2011 TDV8, I bought it 5 years ago in August 2020, and even though it was full main dealer history, I forced myself to put £200 a month into a Halifax bank account ( which is used as a piggy bank for the car )
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 103 ![]() ![]() ![]() |
I've had my FF for nearly 2 years, and in that time it's been my daily drive. Only let me down once [gear selector] 15K miles a year, and approximately 4K in maintenance bills, I'd like to run cheaper cars, but I just don't like any of them.
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 269 ![]() ![]() ![]() |
My last 2 have been lemons. A 2014 5.0ltr S/C and a 2017 Sport.
There seems to be at least some consensus of opinion here, like I said 90% great, but badly let down by 10% of sh*t components, probably as a result of bean-counter influence, plus a bit of previous-owner ignorance, not to mention emissions/economy requirements, and outsourcing to asian countries.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 830 ![]() ![]() ![]() |
i spent my time as an apprentice at a rover agency many years ago.
WheelNut Member Since: 30 Jan 2025 Location: Vancouver, Canada Posts: 25 ![]() ![]() ![]() |
Pretty simple answer here: Range Rovers aren't reliable relative to the average everyday car. Most people aren't familiar with hyper complex 4x4s. Most people are familiar with family sedans with naturally aspirated 4 cylinder engines, manual climate control, steel springs, dampers with fixed valving, FWD, etc. Now, consider the Range Rover: A bill of materials that is likely nearly double the length as a Toyota Camry. Just the air suspension system alone has hundreds of parts rather than FOUR steel springs. Now layer on automatic wipers, heated windshield, rear seat entertainment, cooled seats, V8 engine and on and on. Parts are more expensive that normal cars too, so when it comes time to do even routine maintenance the costs are significantly higher than smaller less complex vehicles. So, in summary there is a lot to go wrong on an RR AND the build quality isn't top of the heap, so there are lots of problems that crop up. Some cars can be neglected pretty heavily and STILL work great and seldom give trouble.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 694 ![]() ![]() ![]() |
I think it's mainly down to costs and ease of maintenance.
