Home > Technical (L322) > Strange noise
Andy
Strange noise
Hi all
My RR keeps emitting a short high pitched sound every few hours. It’s locked so theres nothing active that I can see. It doesn’t sound like the car alarm.
Best way to describe it is like a “wheeep” sound.
Anyone shed any light on this for me? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #725042 24th Sep 2025 5:16pm
JayGee
Could be air being vented from the suspension compressor or a leak as it does it's suspension leveling routines after shutdown. 2012 TDV8 Vogue (L322)
Post #725058 25th Sep 2025 7:56am
Andy
It’s not air. This is an electronic sound like an alarm chirp. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #725060 25th Sep 2025 8:40am
Ian Thompson
By chance, when you return to the vehicle, is your clock date/time reset? Also, when you unlock remotely is the behaviour 'normal', i.e. all doors unlock and door mirrors return to driving position, and no weird alarm sounds? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
2004 TD5 Discovery 2 - gone
2002 Freelander 1.8 - gone
Post #725078 25th Sep 2025 1:08pm
Andy
It’s all fine. No clock reset or anything. I would record the sound but it’s so random and I never know when it’s going to do it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #725086 25th Sep 2025 3:25pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I sometimes get a high'ish pitched electronic sound from my car, when I unlock the car.
I think it's the "Sounder" under the drivers side dash. I think that it must be the parking sensor sounder. Mine seemed to start after I had a bit of a leak caused by the sunroof drain being blocked, but could have just been coincidence.
Might be the same thing with yours and it's completely random, might not have it happen for weeks, then it happens.
Post #725146 26th Sep 2025 1:58pm
