Home > Maintenance & Mods (L405) > Adding Timed/Remote Climate to 2017 model - it can be done
Fifth Horseman
The wiring colours on the heater side of the connector do not correspond to the colours in the vehicle loom eg. black (-ve) in the main loom goes to pin 6, whereas the heater connector pin 6 has a brown cable.
The Eberspächer receiver wiring is different to the Webasto.
For the Eberspächer:
RX connector--Heater connector--Function
Pin 2------------Pin 1------------- +12v
Pin 6------------Pin 6------------- Chassis (0v)
Pin 5------------Pin 4------------- RX signal
Unfortunately I no longer have the vehicle so can't send photos to help.
Post #712161 18th Feb 2025 7:48pm
JoeDoyle
United Kingdom 2017 Range Rover Vogue SE SDV8 Silicon Silver
Thank you very much, invaluable information as I got everything bare. For the signal I’m guessing the green wire shown in the picture ?
Thank you for responding.
Post #712167 18th Feb 2025 9:16pm
Fifth Horseman
Not the green wire
Connections on FFBH side of the connector:
Pin 1 red - 12v
Pin 2 green - fuel pump
Pin 3 - no connection
Pin 4 blue/white - RX signal
Pin 5 blue/yellow - LIN bus to HVAC control
Pin 6 brown - 0v (chassis)
Connections on the main loom side of the connector:
Pin 1 grey/red - 12v
Pin 2 brown/blue - fuel pump
Pin 4 - no connection (would be brown/violet if wiring fitted for FFBH remote)
Pin 5 green - LIN bus to HVAC control
Pin 6 black - 0v (chassis)
HTH
Post #712181 18th Feb 2025 10:31pm
JoeDoyle
Thank you so much really appreciated, if you were closer would have got you to do it.
Thanks again Joe.
Post #712185 18th Feb 2025 11:15pm
JoeDoyle
All working great, programmed 2 remotes,
Had to play with connector, ended up being pin 2 power 5 signal connected to blue/white wire and 6 earth. Without knowing the signal wire it would be a headache.
Did a CCF relearn at the end, no faults at all, no diverter valve fitted.
Thanks to Fifth Horseman for the help
Post #712248 19th Feb 2025 7:31pm
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Excellent info, does anyone know if the RX signal to the heater is +12v from the remote receiver? 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #725199 27th Sep 2025 11:06am
