![]() | Home > Maintenance & Mods (L405) > Head gasket leaking coolant |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
I've never heard of a head gasket failing on the 4.4. Are you sure its not the EGR cooler leaking as this sits in the v of the block. I'd suggest a coolant system sniff test to confirm the presence of exhaust gasses in the coolant as a first step before condemning the head gasket. How much coolant is it losing and is the coolant system remaining pressurised after the engine cools down after a run? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558 ![]() ![]() |
Add a couple of uv dye bottles to the coolant and buy a uv torch and look around when it’s dark. This sort of stuff… don’t be shy in adding it in , the L405 coolant capacity is larger than a lot of cars. The stuff I used is no longer available, but this kit looks spot on as it includes the torch. I’d throw both bottles in from the outset .
Bikeracer Member Since: 24 Aug 2023 Location: Newark Posts: 23 ![]() ![]() ![]() |
Thanks for the reply, I can only go on what the mechanic told me. The car went in in Feb for a coolant leak and it was diagnosed as the oil cooler that stis in top of the engine, had this repaired, however I still have a loss of coolant amounting to nearly four litres in 1600 miles. This is where the mechanic has now diagnosed a leaking head gasket. I have to admit that I don't feel confident in the second diagnosis and also wonder if the oil cooler was actually culprit initially. I have found a different indie garage not too far away and I'll arrange a second opinion on this coolant loss as soon as I have the all clear to drive after a catarract replacement. At least he answers the phone and doesn't decide after I made an appointment that he is shutting down for five weeks for the childrens holidays and reappoints my visit. . Last edited by Bikeracer on 27th Sep 2025 5:37pm. Edited 2 times in total |
Thanks, I've already added two bottles in and I'll add another when I can get it booked in somewhere else for a second opinion. |
Last comment for the moment … don’t assume it’s only leaking at the V area.
Was the indie, Range Rover World? If so good.luck with "Charles" (which isn't his real name).
You are correct about the identity of the indie garage being RRWorld, however the 'technician' was Glen.
