Home > Technical (L322) > 4.4 TDV8 oil leak from bottom end.
BAZ8046
Just a quick update on the oil leak.
After replacing the egr to block gasket, and cleaning as best as I could, it is better.
I’ve done around 1,500 miles since and whilst not completely dry it’s not making the mess on the under tray that is was before.
I would say it is 80 to 90% better which tells me the oil could well be from the top.
I’ll keep monitoring and let you know if it finally dries up. 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #725234 27th Sep 2025 6:23pm
