Home > Maintenance & Mods (L405) > Serpentine belt and idler pulley replacement
Green
Hi
My car decided to throw a fit yesterday and the recovery agent discovered the serpentine belt had come off and the idler pulley had melted (quite annoying bearing in mind it was serviced a month ago).
Anyhow, the recovery agent thought I could replace this all myself and so i'm going to give it a go.
Has anyone else tried/got any tips?
Post #725316 29th Sep 2025 10:37am
Bardley
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
V6?
Access from both top and underneath with the undertray removed. There's a plastic cover that is on the drivers arch side that also helps access. L405 2014 SDV8 4.4 Autobiography
Corris Grey
Previously 2011 D4 SDV6 HSE Santorini
Post #725317 29th Sep 2025 10:51am
Green
Thanks Bardley
Yeah, it's the V6. I'd just decided to edit my post to say that but you beat me to it.
I'm just about to go and pick the parts up but have no skills at all...worried is the word but it's already broken...i'm guessing I can't make it any worse! Laughing
Post #725318 29th Sep 2025 10:56am
Green
Fitting the pully - 2 mins
Fitting the belt - 2 mins
However, I can't find the right size socket head for the belt tensioner...hours! Anyone have any idea what size? I've tried a 10mm and its too fat to fit, 9mm got wedged in, 8mm fit in but doesn't seem to grab anything.
Post #725346 29th Sep 2025 4:04pm
fisha
They often have a square hole which takes the square peg of an extension bar from a socket set. You plonk it in, and use the extension bar to pull back against the tension to release the pressure on the belt.
( Is that what you're asking about ? ) V8 or else ...
Post #725388 29th Sep 2025 10:21pm
