Home > Technical (L322) > Vibration in steering wheel at 70mph
Mr_Natural
United States 2012 Range Rover Supercharged 5.0 SC V8 Sumatra Black
I'm getting a vibration through the steering wheel starting right around 70mph but goes away above the upper 70s.
So far I've:
- Replaced all the front suspension components such as control arms, ball joints, bushings, anti-sway bar end links, etc.
- The tires are new and have been balanced. This started when the old tires were on the car and i had those balanced too, including the 3rd time they did them we did a road force balance. Wheels were checked at the time the new tires were mounted to make sure they are running true and they are good.
- Alignment has been done a couple of times since this started and it makes no difference
- New brake rotors (and pads)
The vibration was a bit better after replacing the rotors, so now i'm wondering if it could be something else in that area? Is there any other rotational component related to rotors that could be causing the issue?
What else would you look at?
Subframe bushings? I'm inclined to think not, since the handling is great other than the vibration. When I had a really weird suspension issue in the rear where the car was very unsettled going over bumps, and after replacing the subframe bushings tht went away. The point of mentioning that is that the bad bushings were very noticeable. The front is great other than vibration. No weirdness over bumps.
Other things i can think of: Steering rack, bushings in the steering column? CVs? Drive or prop shaft bearings or balance?
Post #725163 26th Sep 2025 4:05pm
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Worth checking the rear prop shaft bearing.
I had a similar vibration at 70 mph and it was a knackered bearing. All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #725303 28th Sep 2025 11:02pm
Mr_Natural
thanks for the info, Chris. Would the rear prop shaft bearing show itself through the steering wheel?
I found an imbalance in the propshaft on a different car and it was more of a shaking of the whole car
Post #725347 29th Sep 2025 4:17pm
fisha
Generally for me, if you feel it in your seat, its the rear. If you feel it in the steering wheel, its in the front.
So, a few more questions:
- Does it do it all the time at that speed regardless of road? or do you notice it on a section of road which you typically will drive up and through 70mph ( like going onto a motorway / highway ) ?
- Do you feel vibration when you make gentle changes away from straight ahead when on gentle winding roads ? or very gentle slalom-ing it.
Other rotation parts: The front drive shafts, if there is play / imbalance in them, I supposed you could feel that through the steering. Can you feel any play in them at all? V8 or else ...
Post #725387 29th Sep 2025 10:06pm
Paddy X350
I suppose its worth checking just to eliminate, it is a common failure item I think from reading posts here, and mine was absolutely gone. All the best
Chris
Others;
2003 Jaguar Xjr
Post #725410 30th Sep 2025 2:10pm
Mr_Natural
hi fisha,
Yes it does it on any road at that speed. It's quite consistent.
I'll check to see if being on a curve makes a difference. I hadn't thought to check that.
I'll also check the front propshaft for play.
Post #725415 30th Sep 2025 2:49pm
Mr_Natural
good idea. The suspension parts were really bad when i replaced those so i'm guessing a lot of other things are worn on a car of this age. It seems a lot of luxury cars hit end of warranty and people quit doing the maintenance on them to save money (especially if they bought the car at the very top of their budget) and then finally sell them on once too many things start needing attention.
Post #725416 30th Sep 2025 2:52pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I’m on my 3rd rear prop shaft
The symptoms i experienced of the failing bearings was noise which increased with speed - I didn’t experience vibration which only happened within a small mph bandwidth.
These bearings - and the housings do fail. Worth checking regularly in any event. My first prop shaft lasted >100k miles. The 2nd was obviously defective as it lasted only 10k miles. 3rd prop shaft is at 25k miles and problem free so far.
IMHO your symptoms don’t sound like rear prop shaft bearing failure to me.
Post #725427 30th Sep 2025 4:50pm
MilesBFree
United States
Thanks Rambles
Post #725478 1st Oct 2025 4:37pm
