Home > Technical (L322) > TDV8 4.4 started with a tapping noise!
B19DMJ
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Hi All,
returning from a shopping trip on Saturday up the A1 and all was well but as I turned into the driveway I heard some strange noises. There was a metallic grating sound for a second or so and a tapping sound which continued. I parked up and turned off the engine. Started it back up and the tapping continued and a squeaky grinding noise again only for a second. As I opened the bonnet, the grinding noise had stopped but the ticking continued. this gets louder as the engine revs increase.
The noise seems to be coming from the front top passenger side of the engine. While stood scratching my head wondering what was up now there was a couple of small squeaks rather like a bit of morse code and the tapping noise stopped. I turned the engine off and restarted it. No noise! as I revved the engine gently the tapping came back. No grinding or squeaking though.
Any suggestions of what this could be would be appreciated.
2012 with 116000 miles
Post #725431 30th Sep 2025 5:13pm
kevinp
Could be a collapsed bearing somewhere along the serpentine belt?
Post #725439 30th Sep 2025 6:36pm
D3Jon
Sounds to me like the auxiliary'serpentine' belt tensioner failing - the housing cracks and the belt starts to run off the edge of the pulley. Common issue on this engine, usually around the mileage you have.
Not mega urgent, but you need to get it looked at reasonably soon, they can fail completely, and then the belt can break a few bits as it tries to leave the engine bay.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #725456 30th Sep 2025 10:17pm
B19DMJ
Thanks for your replies.
Once the rain subsides I will give it a look at Very Happy
Post #725462 1st Oct 2025 8:53am
