Home > Technical (L322) > Transmission Fault, No Codes
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Hi all,
Have had a 'transmission fault' message a couple of times in the last two weeks.
It doesn't go into limp mode and it disappears almost immediately.
Is this anything to worry about? Should I just keep on driving?
Transmission fluid changed recently, mileage is 158,000.
Have looked with the GAP tool and no codes recorded. All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #725302 28th Sep 2025 10:56pm
Paddy X350
So got the transmission fault on the instrument cluster again today after hard acceleration when joining the motorway. Then I think the transmission was slipping in 6th gear. I know I should have 2000 rpm at 70 mph and I was only doing 65 at slightly over 2000rpm.
Driving normally at lower speeds/gears.
Checked for codes in the transmission module when I got home and no codes.
ZF/automatic gearbox specialists are a bit thin on the ground here. The one I know and have spoken to thinks it is a failing E clutch due to bushing wear and the transmission needs a full rebuild at a eyewatering cost of 3500 Euro, ouch.
Any Irish members know of a good specialist?
Any advice or comments very welcome... All the best
Chris
Others;
2003 Jaguar Xjr
Post #725473 1st Oct 2025 3:27pm
