Home > Maintenance & Mods (L405) > Perceived loss of stability
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Not sure if I’m imagining it, but my 2014 L405 seems to have gone ever so slightly floaty on the road. Like it's had one too many sherries and now thinks it's a yacht. Could be a sway bar issue. Could be the ACE system having a nap. Either way, I’ll have it checked out, but I’m curious. Has anyone else experienced this, or am I losing my marbles?
Post #725522 3rd Oct 2025 3:38am
fisha
The car should tell you if it thinks it’s leaning too much. It throws errors on the dash for that.
You can also look underneath, there will be damp patches where oil leaks from the pipes. V8 or else ...
Post #725527 3rd Oct 2025 8:37am
Gremlin500
Has it had the front lower arms replaced in the last few years?
The big rubber bushes at the front of the arm are a consumable item, as per other suspension bushings.
These:
If worn out, the car feels very woolly & wayward, and tends to understeer on roundabouts, etc.
Hard to check these yourself, unless you have a lift and long pry bar. V6 Vogue - “Less is More” - less to go wrong!
Post #725535 3rd Oct 2025 11:57am
Salsbury
Thanks, probably more than due for those arms and rubber bits.
Post #725550 3rd Oct 2025 3:01pm
cass
I’d start with a 4 wheel alignment check on something like a Hunter machine. The check is normally free and you only pay to get adjustments done.
Anything worn will usually show up.
Post #725559 3rd Oct 2025 5:21pm
