Mine looked the same, I put it back together again and used JB weld RVT Gasket maker over the original gaskets, I didn't know that new ones are available, otherwise I would have used them.
The workshop manual is not very useful in getting to the Oil/ fuel cooler/ breather, I used the info on this site,
https://www.fullfatrr.com/forum/topic32601.html
Whilst I was there I also replaced the seal of the whole block, part no: LR002340, it will mean removing the EGR valves and a lot more coolant hoses but under the age old motto: whilst I'm in there I will replace...
You also have to remove/ loosen the thermostate housing to get to one bolt. I have loads of bits of video that I am planning to splice together into some cohesive story to assist, let me know at what point you are getting stuck and I will send you the relevant bit
the Workshop manual is in the WIKI top right on the page.
Will
