Home > Maintenance & Mods (L322) > Second battery
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Second battery
Hi all
I want to install a second battery in my 2002 Vogue TD6. Although I have seen several people connect this second battery to the cable at the rear and go through a 140 Amp relay, I have read that a second battery should be connected with a VSR (Voltage Sensitive Relay) using a 25mm² cable from the main battery to the rear where the other one will be.
I would like to read your opinion?
Cheers
Post #725595 4th Oct 2025 12:28pm
I’ve had a second battery installed in the rear for years connected directly to the 100A cable supplying the rear fuse board and a local earth. Never had a problem. I’ve also installed a battery isolator to the front battery.
Switched the front battery off once and then started the car using the rear battery, it just started as normal, the 100A fuse on the rear cable seems to have a bit of tolerance.
Can’t see the point of over complicating the instal. Thumbs Up
Post #725615 4th Oct 2025 5:01pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
I have done same as @nicedayforit on both L322 so thats best part of 10 years with no issues only difference is I fitted isolator to rear battery.
Post #725626 4th Oct 2025 10:09pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Fitted a second battery in the RH boot space, permanently connected to the 100A terminal.
There is a 100A resettable fuse just in case but it has never tripped in five years.
I installed a pair of new Varta AGM batteries to keep things reasonably balanced and topped up by a CTEC charger when not in use.
Simple works fine. Forty years of progress. 1972-2012
Post #725642 5th Oct 2025 11:39am
