Home > Maintenance & Mods (L322) > 4.4tdv8 oil change - double flush?
Grimreaper
Ireland 2012 Range Rover Vogue 4.4 V8 Bournville
Hi folks
Doing my first engine oil change on a new to me 2012 4.4tdv8.
Is it best to drain the oil rather than suck it out?
And is it best practice to run an additive and change oil x2 or is that overkill?
Rgds
Bren
Post #725100 25th Sep 2025 6:23pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Vacuum pump gets most of it
I don’t use a flush
Just change 2x a year or every 6k miles whichever gives the most frequent interval
Use quality oil that meets or exceeds the spec requirement
Post #725103 25th Sep 2025 6:52pm
JayGee
Did it come with a service history so you know when the last change was? If not and you suspect it's been neglected it may be worth draining from the sump as this may remove any sludge buildup which can't be sucked up through the narrower tube. 2x oil changes per year are usualy sufficient but again if it's been neglected you could fill with the cheapest oil, run it up to temperature and then drain and refill with proper stuff to be sure. Make sure you use C1 grade for the final fill but it doesn't have to be a fancy high performance spec or brand as soot loading and dilution with diesel from DPF regens are the main reasons to change the oil and not any breakdown in the base stock itself unless you are using it for heavy towing or serious off road competition use. 2012 TDV8 Vogue (L322)
Post #725125 26th Sep 2025 8:28am
GGDR
which oil are we using at the moment guys?
my oil change is coming up due
I used Petronas from Opie last time. Cheers, Greg
Post #725132 26th Sep 2025 9:47am
JayGee
I use the same or the equivalent from S&A and see no reason to change. 2012 TDV8 Vogue (L322)
Post #725135 26th Sep 2025 10:15am
Grimreaper
Hi Yes there is good history 13 stamps
It'll be my first service so was gonna go belt & braces & was just wondering what the consensus was across the forum about service oil changes
Thanks for input
Post #725297 28th Sep 2025 9:03pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
I concur, twice a year with Smith & Allan 'Momentum' C1. One drained, the other vacuumed.
Overkill as I only do 3000 miles a year but cheaper than an unavailable new engine. Forty years of progress. 1972-2012
Post #725650 5th Oct 2025 2:59pm
Fox889
Everyone has their “favourite” oil, personally I go for Shell Helix AJ-L especially when Opie do a special.
I see you’ve still got your 4.4…….i made a comment, must be six years ago, when I was looking for one as yours is the colour combo I was looking for, you had some cool ‘London’ photos.
 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #725682 6th Oct 2025 8:40am
D3Jon
Re: 4.4tdv8 oil change - double flush?
Grimreaper wrote:
Hi folks
Rgds
Bren
If you mean an engine flush additive, then that's generally regarded as bad practice these days. Modern oils have plenty of detergents already, and a well maintained car won't need any sort of flush additive.
The detergents present in engine flushing additives are very harsh and can reportedly damage engine seals and also dislodge useful deposits that are helping slightly worn seals keep oil inside the engine.
Best to avoid, in my opinion. There's a video on YouTube somewhere discussing how damaging a flush additive can be to your engine.
As the car is new to you, I think the best advice (as stated by others), is to put in some cheaper oil of the correct spec, run it up to temperature and then drop that out. Or if you're feeling 'flush' (geddit...), do a double change with your more expensive oil!
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #725688 6th Oct 2025 10:07am
pcourtney
I concur - Jon is spot on - avoid all these additives, its not what you want in your engines !
Post #725716 6th Oct 2025 5:24pm
