![]() | Home > General > Wiki |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
What program are you using to open it?
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569 ![]() ![]() ![]() |
I just downloaded from the Wiki as a pdf. I'm using MS Windows 11. I should add that so far as IT is concerned, I am simply a user!
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 313 ![]() ![]() |
When I downloaded it, it was split into folders for each section. I can't remember how I did it or if it was a zip file.
Definitely doesn't look like that!! Drives:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
the one I have on my Mac is in folders there is no search as such but the folders are labelled with the general area.... so its pretty easy to find what you are looking for. There is nothing that can't be fixed with a hammer😜😜
I must be doing something wrong then! Drives:
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 233 ![]() ![]() ![]() |
If using Adobe Acrobat or similar on a Windows machine once the you open the file, ctrl-F will open the find window and will allow searching within the document. |
my bad, I'm thinking 405 WM. the 322 WM is indeed a 3000+ page long PDF. though on mine the contents at the start of the doc are clickable and it takes you to the relevant part.
