Home > Technical (L322) > Anybody know what this little box is
diabloam
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
After £1700 in parts, I have now fitted new rear HB shoes plus fitting kit, new rear prop, terrafirma slotted discs and EBC green stuff pads all-round along with two new front aerosus air struts. All seems well for the best part, however I had the arch liner out and when I was putting it back in on driver side i noticed a little fairly exposed electrical block, so
Can anybody tell me what it is and should it have a full cover over it?
any suggestions? thanks
Post #725703 6th Oct 2025 12:18pm
Mikey
Cover for the ABS connector (and pad wear sensor, depending which side)
Post #725705 6th Oct 2025 1:08pm
diabloam
it just looked like there was a little green board in it and not connectors, but thats fine if that is what it is. So I dont have cover missing then, thats the way they are
Post #725706 6th Oct 2025 1:29pm
stuart_2006
Some ABS connectors and blue, some green. So you might just be seeing the green connector. They're quite chunky.
Post #725720 6th Oct 2025 7:12pm
