Home > Technical (L322) > 4.4 TDV8 air temperature/density sensor loom socket
MarkTS
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Hello All
I replaced the oil cooler in my 2011 4.4 on Sunday, which was a long job, when at least a third of the time was spent cleaning all the accumulated carbon/oil deposit that was caked in every part of the inlet system, the doughnut in particular is a right pain and I would need a proper large degreasing tank to get all the crap out. Anyway the final step was putting the throttle body back on and the intercooler elbow/pipe. When I connected the temp/density sensor, the little plastic retaining piece in the socket (on the loom) broke off and now the sensor and socket are held together with a cable tie around the hard plastic elbow. I contacted JLR, and as I expected, the socket is not available as a separate item, but only as part of the loom. There are some looms on ebay, but I don't really want to pay £100 to obtain a single socket that is worth only pennies. By some off chance does anyone know where such a socket could be obtained?
Thanks
Post #725713 6th Oct 2025 5:02pm
toby1
Try this for starters: https://www.fullfatrr.com/forum/topic73669.html 2012 Vogue TDV8 in Aintree green over sand
Post #725719 6th Oct 2025 7:49pm
MarkTS
Thanks Toby1 for the suggestion.
I have found the socket, following some forensic level searching on the interweb:
Ford Duratec ST150 ST170 Camshaft Sensor Connector / Cam shaft plug 2 way LX43
This is also used on temp sensors. The 4.4 is a Ford engine so makes sense. I've ordered a replacement from Brands Hatch Performance https://www.shopbhp.com/
184004-1
Automotive Connector Housing, SSC, Plug, 2 Ways, AMP SSC Series Automotive Socket Contacts
Post #725784 7th Oct 2025 5:40pm
