![]() | Home > Maintenance & Mods (L405) > Low SAPS 5W40 synth engine oil |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1851 ![]() ![]() ![]() |
The answer is in my OP on the matter, the best oil is already available: 5W40 C4 ULS, but folks are too busy arguing over the unproven alternatives and the demand remains low, so the price is high. I for one would never put C3/C4 into my Euro 6 car after carefully comparing the ACEA documentation.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3380 ![]() ![]() ![]() |
Oil pressure is not the same as oil flow..... 2012 TDV8 Vogue (L322) |
Did anyone say that? |
If oil flow is restricted due to blocked ports (eg sludge from extended oil drain intervals) or it's viscosity is higher than OE then the oil pressure looks healthy but it may not be flowing enough to protect the bearings. Oil flow is the critical thing which is not directly measurable and only estimated by relating pressure to temp and oil viscosity with an assumed clean engine. 2012 TDV8 Vogue (L322) |
Mohawk Member Since: 07 Oct 2025 Location: Bristol Posts: 9 ![]() ![]() |
What JayGee said. The first number followed by a W in multigrade is the Winter or cold performance fluidity measure & the second number After the W is the Hot performance fluidity measure. So 5w30 & 5w40 act like a 5 weight oil at low temperatures, but when hot as inside an engine at normal operating temperature, one will act like a 30 weight oil & the other like a 40 weight oil. Lower number=thinner oil.
@ Mohawk - "So 5w30 & 5w40 act like a 5 weight oil at low temperatures, but when hot as inside an engine at normal operating temperature, one will act like a 30 weight oil & the other like a 40 weight oil. Lower number=thinner oil."
The 5w rating is the same, but like all oils there is an upper & lower fluidity limit for 5 weight oils at the chosen test temperature, so a 5w30 is probably thinner than a 5w40 at low temps, but both are within the permitted range. One manufacturer to another's oil will be different but within range to state its 5w is 5 weight. So negligible differences unless you live in the Artic. Check out the ball bearing drop test videos for oil viscosity on YouTube comparing different multigrades with the same W number, but usually at very negative degree C temperatures. |
But you agree the oil gets thinner as it warms up? 2012 TDV8 Vogue (L322) |
Yes, Absolutely but 30 gets thinner than 40 & has a lower pressure in the same pumped system & lower shear resistance when warm. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1874 ![]() ![]() |
How do you know a 40 isn't too thick? |
Its not night & day, or say water -v- cold honey or warm honey even. 40 is just a bit more resilient than 30 at higher temperatures.
Too thick an oil on cold start will have more damaging consequences if moving parts are not properly lubricated fast enough. Thicker oil at operating temperatures is not significant for engine wear and may even be beneficial on an older high mileage engine. 2012 TDV8 Vogue (L322) |
Some of us are old enough to remember when most cars were running on 20W50 and acheiving high mileages without any issues, the design of the internal combustion engine hasn’t significantly changed since then.
Modern engines are built to much tighter tollerances and thus can take advantage of lower viscosity oils and not need thick goop to fill the sloppy fit of parts. 2012 TDV8 Vogue (L322) |
