Home > Maintenance & Mods (L322) > Rattle... temsioner or pulley?
-L-
United Kingdom 2011 Range Rover Vogue TDV8 Bonatti Grey
TDV8 2011 L322 with an annoying rattle at the front end which is slightly less when the engine is warm, but noticeable when cold.
I think I've narrowed it down to a pulley or tensioner. One piece of advice I was given was if you're replacing one, you may as well replace them all... A
Any thoughts?
Post #725839 8th Oct 2025 12:52pm
PeteT80
I replaced them all on mine and both belts. Also replaced water pump and alternator while it was stripped down.
Post #725887 8th Oct 2025 11:46pm
-L-
Hi Pete. Did you use OEM or aftermarket? Any idea how long it took?
Post #725912 9th Oct 2025 1:53pm
