Home > Maintenance & Mods (L405) > Which battery is low?
Danwilderspin
So if o leave the car a couple of day it says after 30 seconds or so of the ignition is in - low battery start engine. Go for a drive it goes away unless I leave it sitting.
My question is which battery is low of my two how can I check? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #725725 6th Oct 2025 9:42pm
Kot
I usually just put the ctek on when this comes up usually every 2-3 months. They are power hungry beasts. 2018 SE SDV8 4.4 Byron Blue
Post #725737 7th Oct 2025 8:47am
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Mine kept coming up with the same warning. I replaced the main battery under the spare wheel, reset the BMS and I've not seen the warning since. Mine is 2014 without start stop.
I fitted this one, which Europarts gave me under warranty as my previous one was 2.5 years old and showing signs of weakness - result!
https://www.eurocarparts.com/p/exide-agm-s...-444777006
Post #725738 7th Oct 2025 9:00am
The jump connections on the drivers side of the engine bay are connected direct to the main battery, measure the voltage there, if it's around 12.6 30 mins after charging then it's the second battery, if it's low then the fault lies with the main battery.... Thumbs Up Pete
-Click here for Thread-
Post #725739 7th Oct 2025 9:27am
when i was researching my stop/start disable i'm sure i read in the WM that the aux battery is a 'fill in' for the stop/start system..
i reckon its your main battery Dan....
disconnect the earth on the aux battery and see if you still get that message. ... - .- -.
Post #725747 7th Oct 2025 10:21am
Bardley
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
Or get both checked on a proper tool that'll give you a state of health.
Plenty of these are available on the usual sites.
Search TopDon. L405 2014 SDV8 4.4 Autobiography
Corris Grey
Previously 2011 D4 SDV6 HSE Santorini
Post #725781 7th Oct 2025 5:13pm
Danwilderspin
Ok going to check the 12.6 first - does the little battery need coding? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #725792 7th Oct 2025 8:24pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Re: Which battery is low?
I can tell you that in my case it only appeared when the main (under the boot floor) battery was low. The reason I know this is that my auxiliary battery was knackered, with the BMS reporting it as permanently at 0% state of charge, and I didn't get the low battery warning all the time.
Post #725798 7th Oct 2025 9:26pm
hmallett
Rather than seeing it as coding, it's a case of resetting the BMS' battery statistics. So when you fit a new battery, that reset means that the BMS starts learning the values for your new battery from scratch.
I believe that if you don't reset the BMS, it'll be fine, but I guess maybe it'll take the BMS longer to learn the characteristics of the new battery.
Post #725799 7th Oct 2025 9:32pm
Harry858
United States
I thought the start/stop uses a super capacitor and no longer a battery - so that would be your main battery. It's always on if you have the connected services (remote start/AC/unlock/alarm/monitroring...etc...)
Post #726005 11th Oct 2025 3:55pm
it does on FF's after around 2015...
pic of the vqm
Post #726006 11th Oct 2025 4:10pm
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
My 2017 AB had a full size AGM as the auxiliary battery.
Unsure if applicable to all years but do not think aux battery is monitored in the same way as starter/main battery hence it has no BMS on it. So likely the main battery needing charging/replacement
Post #726046 12th Oct 2025 1:09pm
sullivj
My 2014 has a second battery. When I plugged in my diagnostic tool, it gave me the option of resetting the BMS for both batteries.
Post #726049 12th Oct 2025 2:13pm
