Home > Technical (L405) > 400e noise when first pulling away
Captsolo
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Santorini Black
When I drive the vehicle away first thing, there is a sharp ‘pop’ sound from behind the drivers dash/above the brake pedal. Doesn’t happen during normal driving only after initial start (and not all the time). First time with a used hybrid so not sure if it’s normal.
Post #726062 12th Oct 2025 8:12pm
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
Is the source of the pop inside or outside?
My 2019 makes no noise like this so i suspect that isnt normal, if outside id assume suspension or sticky brakes - inside? Unsure
Post #726077 13th Oct 2025 10:27am
Captsolo
Thanks, it sounds like it’s from inside, drivers side behind the dash/above the brake pedal
Post #726078 13th Oct 2025 10:44am
JamboM3
Interesting, I’d start with inspecting the brake pedal in case it needs a bit of lube but I guess it sounds like a good indie needs to take a look, can’t remember coming across a similar symptom may not be hybrid specific.
Sorry not much help!
Post #726080 13th Oct 2025 10:59am
