Home > Maintenance & Mods (L405) > Preventative Maintenance Tip For £2.76
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Electric windows that drag (mainly through lack of use) can cause actuator failure, which is around £400 per door to fix at the dealer!!
Get yourself a can of silicon spray, lower all of the windows and spray it into the window guide channels. Do the same with the sunroof and you’ll be amazed how quickly they open and close again.
https://amzn.eu/d/4rdp2lH
Prevention is always better than the cure!
Post #726072 13th Oct 2025 12:09am
GraemeS
Australia
My previous source of silicone spray now only stocks silicone oil. I used a couple of drops on a house door key a few days ago but oil doesn't have overspray so a few drops here and there in the window runners might also work well. L405 D350 SE Carpathian Grey D5 19" rims
Post #726073 13th Oct 2025 1:39am
Tiny Timmy
Thanks Im going to give it a go , mine are very slow Sad Like you say not used enough Rolling Eyes
Post #726079 13th Oct 2025 10:48am
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Thumbs Up my toyota hiace are as slow as f@;k
Post #726104 13th Oct 2025 8:00pm
