![]() | Home > Technical (L405) > "Service Required" |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962 ![]() ![]() ![]() |
All good ![]() |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
I change mine every 6k miles without fail. Shel helix ultra and a new filter, oil is always black. I have a special machine that sucks the oil out of the Service tube.
revoke Member Since: 27 Sep 2019 Location: Doncaster Posts: 2 ![]() ![]() |
This letter is definitely worth a read as it expands on the meaning of the phrase "architecture and hardware" contained in JLRP00100:
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 426 ![]() ![]() ![]() |
Just to be clear, are there two service indicators, one specifically for oil, and the other for general servicing? I checked my oil today and it appears to have gone up, not down ![]() I also get a service message with a "spanner" - what does that mean? What's the warning specific to oil dilution getting too high? Thanks |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
It looks like there’s a surplus of diesel on the oil due to failed regens.
I used the back door rather than my idtool only recently (may/june) I’ll use the tool this time now I’ve found it again. I’ll also check the oil level. Geoff |
Duplicate deleted. Geoff |
Here we go again 😩
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 120 ![]() ![]() ![]() |
I would suggest you monitor your DPF regens and don’t stop while it’s doing them. This should avoid oil dilution. 2017 (67) Vogue SE Corinthian Grey |
Thanks, how do I do that? |
1) put the kettle on and make a brew
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1878 ![]() ![]() ![]() |
Another possible convert to the Regeneration Gods…… |
Noted thank you both 👍😁 I will have a read. |
It's just come on again! but its in for a service next month anyway so I'll just ignore it for the time being. Geoff |
