Home > Technical (L405) > Oil Dilution cure
iainvr4
2004 Range Rover Vogue Td6 Java Black
Oil Dilution cure
Is there a cure to the car thinking it is diluting the oil when it’s not? SDv8 4.4. Done a full service and then drove it 400 miles constant motorway with hardly slowing and 1 stop and the service counter went down about 5k.
Post #726145 14th Oct 2025 3:57pm
Gremlin500
NEW MEMBERS PLEASE USE THE BL**DY SEARCH TOOL FFS!!!!!!!
Hi iain, no disrespect intended, but there is now a PLETHORA of information on here on dilution and monitoring regens to prevent failed regens and minimise dilution, so there is no point starting yet another thread on this subject.
Please read the following threads carefully, and post your queries in them, and we will all be pleased to respond accordingly:
https://www.fullfatrr.com/forum/topic60839.html
https://www.fullfatrr.com/forum/topic70332...t=dilution
https://www.fullfatrr.com/forum/topic70559...t=dilution
https://www.fullfatrr.com/forum/topic47263...t=dilution
https://www.fullfatrr.com/forum/topic69344...t=dilution
https://www.fullfatrr.com/forum/topic60754...t=dilution
All found in 2mins using “SEARCH” tool above for the word “DILUTION” Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #726169 14th Oct 2025 11:34pm
iainvr4
Sorry I do find this pretty disrespectful, looking at your profile I have been a member of this site for nearly 10 years more than yourself and fully aware of the search bar. A lot of the posts about this are all about monitoring it which is totally impractical and a lot of false information when it comes to this topic. Especially when the car is reading the information incorrectly! So my question still remains is there a cure for this?
Post #726170 14th Oct 2025 11:40pm
Gremlin500
49 posts in 10 years, and how many of those were supportive of this community?
Regular members including myself are always very keen to help others, the answer to your question already exists in the above threads, further reading and searching may be enlightening.
In short, the algorithm does exaggerate the apparent issue, only physical oil sampling and analysis at regular oil changes will give a true dilution figure.
Solution? Change the vehicle. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #726174 15th Oct 2025 12:03am
