|  | Home > Technical (L322) > L322 4.4 TDV8 Transmission Contamination & Overhaul |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | Do a youtube search. There are a couple of blokes who show a complete stripdown. They say you need a special tool for removing the large retaining rings on the drums. You can't just pry them with a screwdiver because its breaks the edges and then it's scrap.
|  15th Oct 2025 6:23am |
| KeithBennet Member Since: 05 Oct 2025 Location: Wirral Posts: 3      | You are Absolutely right, there are some great videos on youtube for the strip down and rebuild of the box, that's what's given me the confidence to tackle it myself. I'm aware of the special reinforcement tools used to protect the casing, I was going to fabricate my own. My main concern is getting the unit out. I have watched LR Time's youtube channel particularly when they removed the transmission from their 4.4 TDV8 Range Rover, they had to disassemble components in the engine bay to get to electrical connectors and clips, however that was an L405. No idea if the 4.4 TDV8 L322 has the same issue. | ||
|  15th Oct 2025 7:21am |
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575    |
 I'm not being disrespectful here, but if you need a workshop manual telling you how to remove the transmission, are you sure you have the necessary skills to actually strip it down and re-build it? I'm an engineer by profession, have qualifications in Motor Vehicle Technology, consider myself a pretty decent mechanic, but I still leave auto transmission rebuilds to the experts!   Have you considered simply replacing the gearbox with a warranted used unit? These gearboxes seldom go wrong, so they're widely available and pretty cheap from specialist breakers. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) | ||
|  15th Oct 2025 8:15am |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | I agree with what Jon says. I did rebuild a Ford 5r55e gearbox myself but I had a step by step guide using an ATSG manual and installed a Sonnax upgrade kit to the valve body. It was very satisfying getting it working again.
|  15th Oct 2025 8:42am |
| KeithBennet Member Since: 05 Oct 2025 Location: Wirral Posts: 3      | I hear what you are both saying but the reason I got my L322 rather than another classic car is I like working on cars and I'm treating my L322 as my classic car and doing the work on it myself (it's not my daily driver). I know I would be able to get the box out without manuals etc, but that's not the kind of person I am, I'm a fastidious researcher and believe gathering as much information as possible is the best approach. It would be easier to just get a replacement but where's the challenge in that. I would like to learn about the box and know exactly what has gone into it. | ||
|  15th Oct 2025 1:05pm |
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575    | Fair play to you Keith!    | ||
|  15th Oct 2025 1:26pm |
| Posting Rules
