![]() | Home > Maintenance & Mods (L405) > Low SAPS 5W40 synth engine oil |
Mohawk Member Since: 07 Oct 2025 Location: Bristol Posts: 13 ![]() ![]() |
Can't see a way to edit, so correction I bought Castrol Magnatec 5W40 C3. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2767 ![]() ![]() |
That's what I've bought to use in my D350 for the next change. L405 D350 SE Carpathian Grey D5 19" rims |
Checkout Cx oils ! Strange most other DPF/TWC equipped cars from major manufacturers specify C3 !
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
If I had a V6 I'd probably be using this
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 570 ![]() ![]() |
From your link Mohawk, I don't know what they're thinking over at Opie Oils, but their ACEA C4 summary is wrong on both counts... ![]() As Gremlin has said all along, the holy grail for TD/SDV6 owners is a 5w/40 C4 (so higher 'hot' viscosity of 40, same low saps as a C1 for our DPF ash levels, yet a higher HTHS for better engine protection) Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Smith & Allen do a C4 5w-30 with a slightly higher viscosity than their C1 5w-30 which may help if V6 crank failure is due to oil being too thin (which I doubt). C4 seems to be on paper a suitable substitute for C1 and was developed for 'highly stressed' engines which the V6 arguably is compared to the V8. It will take many 10's of thousands of miles before you would notice a significant reduction in DPF regen intervals as the extra ash buildup will be very slow. You could however see a change in mpg over a shorter time depending on how accuratley you monitored it before. 2012 TDV8 Vogue (L322) |
Agree it's not a replacement, if anything, it seems to be an improvement for our purposes - still having a low sulphated ash content of <= 0.5 % m/m, but with an increased HTHS viscosity which should give better engine protection. It probably isn't as fuel efficient, but then I don't think the average LR / RR owner really cares about another 0.1 mpg!
No, but JLR do have terrible exhaust designs in some installations (Evoque, F Pace, etc), with the CAT & DPF being so far down the exhaust train that they are unable to effectively complete a DPF regen.
As JayGee says, you're not going to see any measurable difference, the main thing captured by the DPF is soot from the combustion of diesel fuel, which'll remain the same. Ash on the other hand, accumulates in tiny quantities over many miles from the uncombustable metals present in oil additives. It'll take tens of thousands of miles of average driving for any difference to be observed in ash accumulation. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
So that's where I was going when people were saying you can't use C3. The amounts of oil burned are tiny & the amount that becomes ash even less, so yes DPF will be affected over a long time. Either way the 40's 20% higher HTHS should work better on the bores & high torque, low RPM, low oil pressure regions, like when gassing it from low rpm.
I read an ACEA paper that concluded that a C3 oil will result in a 50% higher ash accumulation over and above that produced by running the same grade C1 oil. The testing was carried out on simulation rigs design to represent 180,000 miles of running. I suppose it stands to reason, given the ratio of SAPS content for C1 & C3 oils (0.5% m/m vs 0.8% m/m). So if you expect an average DPF to require replacement or cleaning of ash at say 200K miles, that's been behind an engine running C1 oil, the same vehicle would require it's DPF cleaning / replacing at just 133K miles. So over the long term (and higher mileages) it does make a difference, plus as the DPF clogs, regens become more frequent and fuel consumption will therefore increase. All of the above argument can all be traded off, of course, by the engine protection offered by a C3 oil. It just goes to show you can't have your cake and eat it, and I suppose the same is true of oil specification choice. ![]() ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) Last edited by D3Jon on 15th Oct 2025 7:26am. Edited 1 time in total |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1019 ![]() ![]() ![]() |
I use C1 oil, but add Extralube ZX1 every oil change - have been doing this for 5 years on MY11 car which is coming up to 200,000 miles ( for me that is the best of both worlds, ZX1 is just worth it for my peace of mind when getting into higher mileages )
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1863 ![]() ![]() ![]() |
Some very interesting debate, which was the point of my raising this thread, but may I respectfully remind members to try to not drift too far off topic, this thread is meant to be a technical discussion about oil, thanks all! |
Good valid post there jaygee - mine is now 2.5v as well and edging towards 200,000 miles, will be looking at removing the DPF and getting it cleaned and put back in place after Xmas, have found a place local to me that can do it for £300 ![]() |
Depending on what's in the ZX1 additive, you could be accelerating your DPF ash build up. But I appreciate that you're using the additive to protect the engine's internals ![]() If it contains compounds of zinc, calcium and other such commonly used anti-wear metals, then it's exactly those non-combustible metals which produce metal sulphates during the combustion process which IS what DPF clogging ash is made up from. Pure lubrication oil produces no ash when combusted. It's the additives used in oil that produce ash, but it's those additives that give us the engine protection we all enjoy from modern oils. I'd be checking what's in the ZX1, if it's anti-wear metals or compounds of metals, then I can't help but think a safer bet would be to use C3 oil as at least you then have a measured dose of such anti-wear metals. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
I looked at ZX1 previously but after some research decided I didn't want it in my engine and more particularly the CAT system as it's described as bonding to metal. EP addatives (which is likley what is in RX1 and refered to in their saftey data document) have been in engine oils for a very long time but had to be removed when CAT's and DPF's were introduced. 2012 TDV8 Vogue (L322) |
