Home > Technical (L322) > looking for coolant hose connector 2012 TDV8 4.4
Folkert
France 2012 Range Rover Vogue TDV8 Baltic Blue
Hi All, I have a MY2012 TDV8 4.4 and while disassembling the donut to be able to replace the oilcooler i pulled the little coolant hose that is connected with a small bracket to the donut. the plastic elbow connector was all brittle and the lower part where the rubber hose slides on just snapped off. Also the rubber ring where the connector is mounted with fell somewhere down below during the incident.
Embarassed
Question: is this a generic part and if so what is this oficially called? or should i just source the LR one by part number? if so... what is the partnumber for this plastic elbow connector?
see pics
Thanks in advance, Folkert
 2012 L322 4.4 TDV8 VOGUE
Baltic Blue, Parchment interior,
Suede Ceiling, Rear Entertainment,
Front Seat Cooling, Tow Kit.
Post #726253 16th Oct 2025 8:33am
kevinp
I think it is part of LR022690. Just done my cooler and replaced all the hoses and connectors possible. Quite a few of the connectors broke on mine with very little force.
Post #726254 16th Oct 2025 9:15am
Folkert
Cheers!!! I indeed see it is part of the top radiator hose kit. i think for now i will just find a universal quick release elbow connector in the correct size. i think i read somewhere 9.98mm is the correct one.
Will give an update. 2012 L322 4.4 TDV8 VOGUE
Post #726256 16th Oct 2025 9:45am
