Home > Technical (L322) > DPF sensor readings
claeszv
Denmark 2011 Range Rover Vogue SE TDV8 Santorini Black
DPF sensor readings
Hi
Can anyone tell me the voltage reading on the dpf sensor when engine not running.
IIdtool says 7.3 volt but the only information I can find is that it should be 5 volts. fitted a ned sensor but readings are the same
I have a full dpf 27.5g and locked in limp mode
L322 2012 4.4 TDV8
Post #726411 18th Oct 2025 9:22pm
Baltic Blue
The only way to clear the limp mode red DPF is to do a Forced Regeneration .
It’s very easy, just follow iid screen instructions.
Post #726438 19th Oct 2025 11:36am
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Mine reads 0.73x volt, engine not running.
Engine (cold) idle: 0.75x volt with a calculated soot concentration of 17.8 gram.
Engine at (warm) 1420 rpm: 0.79x volt, calculated soot now 18.6 gram.
I hope this helps. 2012 4.4TDV8
2000 Honda S2000
Post #726474 19th Oct 2025 7:50pm
claeszv
Thanks a lot. The measures i was looking for Thumbs Up
Post #726491 20th Oct 2025 7:48am
claeszv
Mike.
Tried to do the regen many times. Iidgaptool says "regenerating" but sootlevel just continue rising. I also tried with "fit new particulate filter"
and offcourse cleared DTC's
I guess some readings are not right, since its not regenerating
Post #726492 20th Oct 2025 7:52am
