![]() | Home > Technical (L322) > Vibration when braking |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3392 ![]() ![]() ![]() |
Warped disks or uneven pad deposits are the usual culprits made worse by worn suspension bushings BUT they can easily be warped by over torquing wheel nuts or doing them in the wrong sequence. Try loosening and retorquing. 2012 TDV8 Vogue (L322) |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 207 ![]() ![]() ![]() |
Thanks, the front discs and pads were fitted today. I cleaned and wire brushed all mating surfaces to ensure a correct and true fit of the discs. I will check the rear discs and pads.
Don’t waste time with checking the rears. Upper and lower control arms and their bushings. Wheel nut torque is more crucial than people think due to the design of the hub to disk interface - you did use a torque wrench? 2012 TDV8 Vogue (L322) |
Yes I used and have always used a torque wrench for the wheel nuts. I think this was 100 NM's or maybe 120.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364 ![]() ![]() ![]() |
I would look at the trackrod ends first before diving deeper.
Thanks, this is why I love car forums, great members. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
The control arms can be a struggle due to the ball joint taper fit seizing with rust. Plenty of info on here and on YouTube showing what’s involved. Outer track rod ends are easy to replace but the inners can also have play which is a much more involved job. Mine still slightly judders and I put it down to last time I had new tyres and they did up the nuts with an impact driver which permanently warped the disks or hubs. When I re torqued them I needed all my strength with a breaker bar to loosen them. 140nm doesn’t take much physical effort to reach. 2012 TDV8 Vogue (L322) |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1022 ![]() ![]() ![]() |
and nuts torqued in a certain way - not just one after the other |
How would I check if my hubs are distorted due to a past owner/garage incorrectly tightening the wheel nuts? Would a straight edge steel be adequate or used there a better way to test?
Pug Member Since: 19 Oct 2025 Location: Oxford Posts: 5 ![]() ![]() ![]() |
And when torquing wheel nuts, you keep going round them until the torque wrench clicks without the bolt turning anymore. 3 times is usually enough.
The only real way to check for disk and hub runout is to use an engineers dial test indicator mounted on an arm and magnetic base and reference the tolerances in the workshop manual. Again there are YouTube videos detailing this procedure. A more common reason for brake judder often mistaken for warped disks is uneven pad deposits caused by holding the brakes on hot disks at a standstill. The cure for this is to do repeated high speed hard braking without stopping to recondition the disk surface. 2012 TDV8 Vogue (L322) |
The car pulls dead straight when accelerating and braking, also no noises.
High frequency doesn’t sound like normal brake judder as this is usually low frequency pulsing / once per wheel revolution. Have you been around the wheels touching them after a drive to see if any are very hot as this now sounds more like a stuck caliper. 2012 TDV8 Vogue (L322) |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 704 ![]() ![]() ![]() |
Hi, you might also consider front tyres, bushes & bearings in that order if your comfortable it's not the discs themselves, firstly check for any wear in the fronts and the steering linkage, i.e. is there any excess play.
