Home > Technical (L405) > Surging sound when turning right
DFL405
United Kingdom 2014 Range Rover Autobiography SDV8 Barossa
I wonder if anyone can help. I have a L405 4.4 diesel, when turning right I get a surging sound fron the rear. I would say its from the wheel well. It doesn't happen when turning left and doesn't happen at all when not moving. The air suspension seem fine and no warning lights. It's been getting louder over the past 500 miles. The rear ACE pipes were changed circa 1000 miles ago. The sound 'surging' is what I would describe as a pump sound......like old power steering if that makes sense?
Post #726494 20th Oct 2025 8:39am
there is a TSB for fuel slop in the tank, could be that.. ... - .- -.
Post #726505 20th Oct 2025 12:16pm
DFL405
Possibly, however the sound doesn't sound like 'slopping' it's like a suction sound or compressor sound. Very strange it only happens on a right hand turn.
Post #726506 20th Oct 2025 1:19pm
i wonder if you have a bag leak..try going off road mode and listen for air leaks. ... - .- -.
Post #726510 20th Oct 2025 2:42pm
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Was enough AC fluid replaced after the pipes were renewed? - there are two sets of coolant fluid volume numbers written on the tag under the bonnet depending on the three or four zone a/c.
Do you have the multi-zone air conditioning? - if so, it could be the fan for the rear AC (located behind the boot liner on the left) - pull back the liner (from the top - it is on clips) and make sure the fan is turning and is not clogged when the AC is in operation?
Perhaps drive around with the boot liner off and volunteer/volun-told in the back who can help you further locate and identify the source of the noise. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #726513 20th Oct 2025 4:00pm
