Home > Technical (L405) > SDV8/TDV8 fuel return line questions
heretolearn
Malaysia 2019 Range Rover Vogue SE SDV8 Loire Blue
Hi, I'm writing in hopes someone may be experienced with how a SDV8/TDV8 fuel return path works. I've just sent my injectors for testing and they came back within factory specs so no problems there. As I started tracing on how the return fuel line works I seem to have stumbled across some oddities on the design.
Based on the diagram:
2. Injector leak off return line. 8 injectors return merged into 1 hose which connects to (2) (A) return line. The line later merges with the T joint (B- no 1 way valve) but connects in between of low pressure lift pump and the fuel heater (5) (C) before going back into HPFP.
As I understand the low pressure pump delivers a constant 5 bar fuel pressure. Would this mean the T joint (B) is constantly pushing fuel back to the injector leak off pipes? I tried pushing low pressure air through (A, B, C) openings and air can escape from either ends.
Should the injector leak off return be better being routed back to (3) line as this is the hose where the excess from HPFP and fuel rail being released back into the fuel cooler which ultimately goes back into the fuel tank?
The system doesn't look right to me and I'm not sure if I'm missing anything out. Appreciate your inputs. Thanks.
Post #719473 9th Jun 2025 3:11pm
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
Let me take a stab at answering this. Though someone more knowledgeable can probably do a better job.
As you have pointed out there are two possible Low Pressure lines the injector leak-back fuel can go.
1. Fuel return from High Pressure pump and Pressure Relief Valve. At less than 1 bar of pressure and sometimes even under slight negative pressure. Goes back to the tank through the fuel cooler.
2. Fuel feed to the High Pressure pump. At around 5 bars as you pointed out. Output of Low Pressure pump that goes through the filter.
There are two considerations when deciding where to dump the leak-back fuel.
First, if you think of it in terms of relative pressures and improving overall pumping efficiencies, you have 100s if not thousands of bars of pressure on the inlet side of the injector. So the injector has no problem dumping its excess fuel into a fuel rail that is at a measly 5 bars of pressure. In fact, you just saved some energy by not having to compress that leak-back fluid back up to 5 bars so that it can be ingested again by the High Pressure pump.
Second, and perhaps more important reason, is the piezo fuel injector has a small hydraulic (fuel filled) amplifier in it that couples the stack of piezoelectric ceramic disks to the valve needle in the nozzle. The piezo disk stack has a very small amount of movement (less than 0.1 mm) when energized. This amplifier, also known as the hydraulic ratio transformer, converts that small movement into a larger stroke which then moves the needle. If there is very low or negative pressure (vacuum) on the overflow side of the injector, then the fluid in this hydraulic amplifier drains away. And the amplifier stops working. Causing the whole injector to stop working. This is why having a little +ve pressure on the leak-back side of the injectors is important.
This video at the 4:10 minute mark shows what the amplifier module looks like and how it functions.
[/list]
Post #720606 1st Jul 2025 8:07am
Astanavits
France
What exactly is the problem with the fuel return?
Post #726499 20th Oct 2025 9:34am
heretolearn
Hi all, I managed to find out what is wrong with the vehicle. It was the ECU all along. So I updated the firmware using IID Tool and everything is fine now. Had to go over the entire fuel system including changing all low and high pressure fuel pumps, test injectors, and check all fuel lines of clogs to find out nothings is wrong with the fuel system. The symptoms I was getting is fuel pressure oscallation. At idle the fuel pressure creates a wave of high and low points. You can't feel it but if you use a IID tool it will show up in the logs. Problem appears when I bring the rpm up. It will hit P0088-17 high fuel rail pressure code at precisely 3.6k rpm as the oscallation waves grew between high and low points. It's a lot of work involved but I guess my fuel system will be trouble free for years to come.
Post #726500 20th Oct 2025 9:49am
Astanavits
France
interesting, I have a similar problem with the injection system I replaced the ECU and Last update but nothing to do the problem persists in my case it is not oscillation it is the ECU which controls the pressure at each deceleration 1000bar 600bar and 300bar this making a noise
https://www.fullfatrr.com/forum/topic72660.html
Post #726503 20th Oct 2025 11:34am
heretolearn
Are you referring to the ticking noise at the very end when revs drop back to idle? Mine used to hear that, infact it was also ticking on idle as it was cutting off pressure. So far I haven't noticed any of these problems after flashing the updates file. I'll test it out later today and see if it's audible when I'm outside of the vehicle.
Post #726504 20th Oct 2025 12:01pm
heretolearn
Tested my 2019. Sounds pretty much the same to yours. I noticed the engine tends to be noisier at idle after EGR delete. Not sure if this is the case. Anyway I've checked the logs between ecu desired and actual, it's spot on so I doubt there are any problems there.
Post #726522 20th Oct 2025 5:33pm
Astanavits
France
This is exactly the noise I'm talking about, god thank you I finally found a 4.4L tdv8 owner with an IDD.
Is it possible for us to cross-share our data to close this thread definitely ?
Post #726538 20th Oct 2025 8:47pm
heretolearn
Sure. I can do that. Which data points do you need me to log as cross reference?
Post #726539 20th Oct 2025 9:09pm
Astanavits
France
Thank you very much.
Desired fuel rail pressure PCM
Fuel rail pressure
All battery and alternator voltages
More specifically, can you maintain the engine speed at 800 rpm with the accelerator pedal and then lower it to 750 or 700 rpm, millimeter by millimeter,
around 700 or 750 rpm? Do you have an unstable idle?
Post #726540 20th Oct 2025 9:17pm
