Home > Technical (L322) > Rear Suspension 2012 TDV8
Jason66
United Kingdom 2012 Range Rover Westminster TDV8 Galway Green
The suspension has been sagging slowly over a couple of days on one side. I have recently replaced the front air struts. The rear sat on its bump stops and came up with a suspension fault. I have attempted to do some research and use my Gap IID tool. On checking the voltage on the height sensors the rear left is lower than the rest. Can you just validate that this is probably the issue? Do I need to calibrate the suspension after changing, I haven't got round to it yet for the front, but I can see a disparity on the readings. I also haven't got as far as working out how to do that yet, I'm attempting to teach myself about the car, as you can probably tell...!
 2012 Westminster Aintree/Ivory 4.4TDV8
Post #726515 20th Oct 2025 3:27pm
Pug
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Not sure if yours will be the same as mine but this is what I found with my 2006 L322 which wouldn't calibrate. Spent about 20 hours on and off trying to sort this out.
Likely the brackets are bent.
Drop the car onto its bump stops and see what the voltages are readying then.
I can't remember which way round the front and rear sensors work so some of this is interchangeable.
The front sensors go from 5v to 0v as height increases.
The rear sensors go from 0v to 5v when height increases.
Fronts should both be the same value give or take.
Rears should be the same.
Front left and rear left should add up to 5v, same for the right.
On mine the front right was way out and just needed the bracket bending to get the reading right, after that been faultless since.
Post #726521 20th Oct 2025 4:29pm
Pug
Its also possible all your sensors work the same way in which case your bracket may just need a tweak to get it reading the same. Can test the bracket theory by unclipping the sensor from the suspension arm and move it full range to see what voltages you get. If the voltages are right then reconnect it and just bend it.
Post #726523 20th Oct 2025 4:36pm
Jason66
I think it was on its bump stops when I took the reading. I’ll take a look at the bracket and maybe unclip. Thanks for this. 2012 Westminster Aintree/Ivory 4.4TDV8
Post #726526 20th Oct 2025 4:58pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Re: Rear Suspension 2012 TDV8
This will help:
https://youtu.be/9ot3L4CHPd4?si=jG2qrqGXISW6aeMZ&t=20m
FWIW : I would also suggest a Hunter 4x4 wheel alignment. After I had mine done at GlenRands it was like driving a different vehicle. TDV8 4.4 2012
Post #726527 20th Oct 2025 5:08pm
Pug
Nothing to lose, I prefer free fixes over costly ones 😂
Post #726528 20th Oct 2025 5:09pm
Jason66
Ramblin Man wrote:
This will help:
That’s a great shout on alignment, thank you. Will watch the video. 2012 Westminster Aintree/Ivory 4.4TDV8
Post #726529 20th Oct 2025 5:18pm
pcourtney
and remember to use the GAP IID tool to put the car into "Tight Tolerance" mode before you do the wheel alignment
Post #726642 22nd Oct 2025 4:54pm
RovingCanary
Ramblin Man wrote:
This will help:
How much would Glenrands charge for that? I had my tyres done at a local place but I am not that happy with the alignment they did (they had two goes at it and the wheel is still cocked with a vibration coming through).
I am quite far from Glenrands or I would have taken it there, but I might be going past in the new year.
Post #726654 22nd Oct 2025 7:12pm
JayGee
Glenrands are a lot more expensive than a standard tyre fitter for a Hunter 4 wheel alignment but they will persevere until it’s right which is worth it. I paid around £270 a couple of years back. No point having it done IME unless all your suspension joints and bushings are tested and free of movement or wear. 2012 TDV8 Vogue (L322)
Post #726661 22nd Oct 2025 8:36pm
RovingCanary
Cheers JG, I did my rear suspension bushes earlier in the year, not done the fronts yet, maybe if I replace those I will go for the hunter alignment.
Post #726664 22nd Oct 2025 9:26pm
Jason66
Gotts in Alton did my Grenadier. Digital machine so had a print out of before and after. Adjusted the suspension caster as well. Was the right side of £200. Glenrands are fairly local to me and I need a few other bits doing so will be making my way there at some point. 2012 Westminster Aintree/Ivory 4.4TDV8
Post #726665 22nd Oct 2025 9:36pm
