I find it frustrating that the GAP Tool produces Hex codes like this, rather than P-codes for diagnosing faults. It means that we only have their descriptions to work from, and not the proper codes.
“0x36 Gear monitor 4 fault: General fault” may mean P0734
Similarly, “0x30 Mechanical torque converter monitor fault: General fault” may be P0741 (stuck off), P0742 (stuck on) or P0743 (TCC PWM solenoid circuit issue)
Does anyone know how to translate these IIDTool codes?
Although there may be a mechanical issue with your torque converter lock-up clutch it’s worth ruling out the solenoid and its wiring first. Without any further clarification of the fault codes, I would begin by checking the resistance between pins 3 & 6 at the C1835 transmission ECU connector, to check the integrity of the TCC PWM solenoid and its wiring. You should get a reading of between 10.0 & 11.5Ω
Phil
