![]() | Home > Technical (L322) > Vibration when braking |
| Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 211
Tyres are all in good condition and the car only gets light on road use. I do have another set of perfect condition wheels with almost new Verde tyres I could fit to rule out a tyre issue.
| Pug Member Since: 19 Oct 2025 Location: Oxford Posts: 16
I think your only option now is to get a DTI and perform a runout test on all 4 corners. Something isnt straight or moving about in there. |
| Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 58
Did you replace the rear too? L405 2014 SDV8 4.4 Autobiography
Only replaced the front discs and pads. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
| drakes Member Since: 26 Jan 2009 Location: Consett Posts: 375
If your vibration is being felt through the brake pedal and seats but not through the steering wheel then that implies it is the back that is causing the problem. Could be a warped disc, sticking caliper or sliders although the caliper would probably cause a build up of heat in one of the rear wheels. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
The vibration is most noticeable through brake pedal, seats and floor. Iam going to replace tge rear discs and pads and see what happens. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
I think I have found the problem. My rear discs look perfect on the outside but having removed the passenger side the back is corroded and unevenly worn. Had to pop out for bits so hoping to finish the job tonight and get back to smooth braking. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
