![]() | Home > General > Ingenium i6 Field action |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1562
Surely any EGR can become blocked by the nature of what passes through it ?
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
+1, I don’t see it as an issue as such. While there may be the odd car (of any brand) that has a real problem, I believe that the majority of DPF problems are caused people buying the wrong car. A big diesel engine doing very few miles in short trips by owners obsessed with squeezing every last yard from each gallon will have problems in any brand. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
I have had issues with my D 5, Lr replaced my EGR valve but that was not the issue. in the end it turned out to be the solenoid which controls the turbo actuator. Swapped that and all has been ok ish since. I still have a slight hesitation at around 2250 rpm when accelerating hard, as though it takes a split second for the secondary turbo to kick in. No error codes showing though……. There is nothing that can't be fixed with a hammer😜😜
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777
I understood that the engines have an electric "turbo" (blower?) that operates to fill-in before the real turbo spools-up. L405 D350 SE Carpathian Grey D5 19" rims |
| barbel jim Member Since: 17 Mar 2025 Location: Northamptonshire Posts: 16 |
It’s nothing new…. A lot of new defender owners are already doing interim oil changes every 5000 miles. Even seen LR stating a service is separate to oil service |
yeah my oil is counting down a lot faster than my service counter. Both started at 21000, but ive done about 8000 since the last service and its telling me I need an oil change in 7000 miles... its getting done at 10,000 whatever the car tells me.
| All times are GMT |
