![]() | Home > Technical (L322) > Manual Reset of *Service Required* - L322 2010 LCD |
| CADjockey Member Since: 24 Jun 2014 Location: West Midlands Posts: 19
Is there a manual way of resetting the *Service Required* message on a 2010 FFRR Vogue
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
i think it is ...an iidtool would reset it .. ... - .- -.
I was afraid of that. The lack of anything on YouTube or anywhere else I can search
See below… |
| JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 811
From one of the L322 (4.4 TDV8) groups on the book of faces this morning:
Not sure if this is a wind-up or not, so anyone who doesn't have an IID tool might want to give it a try and report back. The older I get, the more I realise that people confuse wrinkles for wisdom |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Worth a try and then check on the IID if oil dilution is reset to 0. That's the acid test I'd suggest.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032
can confirm that works - what a back door |
| glenney Member Since: 04 Jan 2021 Location: East Sussex Posts: 21
Yes the door and bonnet thing worked for me too |
| RobWCanada Member Since: 24 Mar 2025 Location: Ontario Posts: 9
Sorry fellas gotta wake this thread up. I have GAP and i reset this no problem. My question is around this “Check on the IID if oil dilution is reset to 0” I’m pretty sure I’ve searched everywhere…this oil dilution is not found. Where is this value? I wanted to look before I reset it but couldn’t find it in any of the menus. Rob 2011 Range Rover L322 SC - Autobiography (Ipanema Sand) Ontario, Canada |
Live Values in the IID
Which section was that in?
| toronnoRR Member Since: 26 Feb 2024 Location: toronto Posts: 18
I feel it might be specifically for the diesel engines...... |
yes it is - makes no sense for GAP to make it available for Petrol engines, it's a diesel DPF thing |
| RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 93
Does that oil dilution number actually change how the engine runs, or just for information? |
| All times are GMT |
