![]() | Home > Technical (L405) > Another deployable steps issue! |
| balsingh15 Member Since: 26 Dec 2020 Location: Hampshire Posts: 12
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
Have you tried standing on it , full weight might get it to move back into position . 2019 SV AB Dynamic Scafel Grey |
Yep tried that but it doesn’t always make it out and when it does, it gets caught on the trim. I’ve used a wood wedge between the trim and the step and that seems to help it out. Also caned a can of HSS 2000 spray on the pins. It seems to be jamming there and not pivoting correctly. |
Mine was jammed , bouncing out then straight back . Battered it with the pressure washer and loads of acf50, then put in roof access mode which forces them to lock out deployed , giving better access into the pivots . 2019 SV AB Dynamic Scafel Grey |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1895
They all jam if not rigorously maintained a few times a year, but this doesn’t explain why they are coming up higher than they should & catching the trim, so needs further investigation.
| All times are GMT |
