![]() | Home > Maintenance & Mods (L322) > The search for the coolant leak. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Well started the search for my coolant leak and I currently have the inlet and water valey stripped. Have found many small leaks. Will post some pics later. But it's going good. Fill you in later. Loads of pics for you. |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 ![]() ![]() ![]() |
will be very interested your findings Rob2529 |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
yes me to "RANGEISM WILL NOT BE TOLERATED"
Will put pics on when I get in. Up to now a very straight forward job. Big but simple enough. Looks worse than it is. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Start with engine cover removed
Trist78 Member Since: 07 May 2011 Location: Worcester Posts: 78 ![]() ![]() |
Looks very time consuming
She's done 91k. Took about 3 hours to strip so hoping it goes back together today a bit quicker. Took most of the day to get where I'm upto with stripping and then prepping and cleaning ready for rebuild. It's actually a simple job. Think the biggest spanner was a 13mm an that was for removing the pollen filter housing. Everything else was a 10mm. I got quoted 4hours by my local Indy which is probably doable if you do it every day. We lost alot of time disconnecting the injector haness's. They are in a crap position and have the cOnectors with the metal retaining clip but there the worst way you could think! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Jobs complete. No leaks as yet but its early days |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
Good post Rob, I hope it's sorted your leak. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi did it sort it out then?
Hi
