![]() | Home > Maintenance & Mods (L405) > Auto Start Stop Disabled with GAP tool |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2776
That is what I set but so far it doesn't work on my MY21.5 D350.
| jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 201
try to set ccf "as built" - you can do that with topix or ask gap to give that file*
If last user mode hasn't started working in a couple of weeks and the fault that occurred prior to any CCF changes doesn't re-occur or does re-occur but doesn't have any connection with stop-start disabling then I'll reset that setting to see if the configuration errors then don't return.
if you have wrong configuration. i.e. IMC looks for not existing modules, or could not get correct answer from existing ones then it will restart or initialise again so why you can get unusal long starting of unit. |
The only parameter that could be wrong by my changes is the start-stop last user mode being enabled if the software doesn't allow the setting. However this one from the IMC
if it starts in 30 seconds then is normal. If starts, then after few seconds restarts again or starts over minute then it is not normal.
The displays don't restart and most of the time 30 seconds sounds about right, but sometimes can take a lot longer. If I was parked then I'm gone in under 5 seconds. L405 D350 SE Carpathian Grey D5 19" rims |
It appears that start-stop has been disabled on my D350. Even though the disabled icon isn't displayed permanently, the engine doesn't stop whilst waiting at traffic lights and after a few seconds the disabled start-stop icon appears which then goes away when moving again. L405 D350 SE Carpathian Grey D5 19" rims |
| 425RR Member Since: 26 Oct 2025 Location: Snoqualmie, WA Posts: 2
Thank you sir for the cheap quick way to delete one of the most annoying features of new cars! Took all of 5 min and no error messages or faults. Brilliant!!!! Jeremy |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
yay!! |
| All times are GMT |
