Home > Technical (L322) > C1A08-1C, pressure sensor supply voltage out of range
robertcope
United States 2011 Range Rover HSE 5.0 V8 Ipanema Sand
Hello! I recently purchased a 2011 L322 (LHD). I has started throwing a code, C1A08-1C, indicating that the supply voltage to the pressure sensor is out of range. When I read the live data with IID tool, it shows 0.980V. Using a volt meter, I read 5V at the connector, both while plugged into the sensor and while unplugged from the sensor.
I assumed that supply voltage must be measured in the module and thought that the module must have an internal issue, so I bought a used module and swapped it out... but it gives the same result.
The pressure sensor will report higher voltages, ie I've seen 2+V from it, which aligns with me actually reading 5V at the connector.
I'm at a loss as to what/where the issue could be. The wiring is utterly simple back there, and a very short run between the switch and module, and it all measures correctly as best as I can tell. The module is connected to the rest of the system via the CAN bus, which... if there was a physical issue there, I'd expect a lot more problems?
Would love any insights that you might have. Thanks!
Post #673018 9th Sep 2023 1:28am
robertcope
This morning, I decided to try and simply the circuit, so to speak. I started by disconnecting the height sensors, which are the other sensors receiving a 5V signal. No change with them disconnected. Of course, if there was a short there, maybe that isn't surprising.
Next, I pulled the module out from behind the fuseblock so that I could more easily test things. I started by pulling the small connector that contains the wiring to the pressure switch. Interestingly, even with the plug disconnected, the ECU reports .980V to it; I'm not very good with electricity, but this makes no sense to me... doesn't there have to be some resistance/ground for a current to be present?
I tried my "new, used" module again, and get the same result. I also pulled the "large, middle" plug to the ECU, no change. I couldn't pull the outer two plugs without the module shutting down.
At this point, I am out of ideas. I feel like it must be something relatively simple, but... I have no idea what.
Post #673040 9th Sep 2023 4:15pm
Phoenix
Check for corroded fuses, I've had more than a few issues with EAS due to this. Open circuit voltages can be misleading as the control module will recognise something is disconnected, get a decent set of backprobe pins and an accurate voltmeter.
Post #673046 9th Sep 2023 6:26pm
robertcope
I'll take a look. But every other signal, function coming from the EAS module is working fine. Everything I measure says that this circuit is fine, too. I've checked continuity of the wires, checked them for shorts/grounds, etc. Everything is nominal according to my measurements. I've added jumper wires to ground, for the 5V line, etc. I've unplugged the connector from the ECU, it still reads .980V. I grounded the 5V line from the ECU and it did move, to 0.990V. I'm stumped.
Edit: I should also point out that when I clear codes, until the ECU runs its check, the car functions normally. I haven't figured out what triggers the code. Sometimes it seems immediate, other times it's a day.
Post #673047 9th Sep 2023 6:28pm
davidrosenbloom
2009 Range Rover HSE 4.4 V8 Chawton White
Oh Im hoping you figured this out can you update me?
I have exactly the same issue; I cant reproduce it however; it seems like when I go uphill it triggers and I lose all values inthe GAP tool;
Update?
Thanks,
Dave
09 FFRR HSE
12 FFRR HSE
Post #726863 26th Oct 2025 12:00am
robertcope
I replaced the air pressure sensor and it's been okay since then. The signal values are still bad, but I guess it isn't doing the check.
Post #726865 26th Oct 2025 12:07am
davidrosenbloom
Where did you source the sensor? JLR? And did that fix the cycling as well? ANd did yours expell gas because my gallery is dropping from 200-35 lbs and also Ive bumped that sensor (were talking about the one on the EAS compressor valve body correct? Under the spare tire? I would think giving it a knock would produce same thing - did you try that?
Thanks,
Dave
Post #726867 26th Oct 2025 12:11am
robertcope
My system worked fine, except when it stopped working because of the code. I believe it was sensor RQH500011. Yes, the one on the compressor valve body (I believe it's the only one). I probably got it from FCPEuro. I don't think giving it a knock would have achieved anything, but anything is possible!
Post #726870 26th Oct 2025 12:33am
Roosterrs
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Look at my post for Air Suspension Fault regarding the sensor issue. In my case I think the sensor went into error thinking there was a vacuum in the gallery compared to atmospheric pressures.
4x4Airseals do the sensor and desiccant kit along with an O ring kit for compressor service.
Post #726887 26th Oct 2025 7:49am
davidrosenbloom
I don't think they do one for the ncj pressings one but i've asked. I do have a working or non weird identical compressors on my 12 but I am LOATHE to touch a running rangie.
Dave
Post #726944 26th Oct 2025 9:59pm
