Home > Technical (L322) > Engine power limited / air mass value 12690g/h
LandyKendy
Germany 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Range Rover 4.4 TDV8 (448DT), 313 HP, 2011 – Engine power limited / Error code P006A-00 / Mass air flow 12690 g/h
Hello everyone,
I've been searching for the cause of the following error on my Range Rover L322 with the 4.4-liter TDV8 (448DT, 313 HP, 2011) for over four weeks:
Problem:
The engine power is repeatedly limited, error code P006A-00 (mass air flow vs. boost pressure correlation).
What I've done so far:
Replaced the mass air flow sensor
Checked all cables (including under load)
Transferred the mass air flow sensor cable for testing
Reset the control unit
Performed a smoke test
Anomaly in the live data:
Even with the ignition on (engine off), one side shows a fixed air mass value of 12,690 g/h, while the other side is correctly set to 0 g/h.
After starting, the values ​​naturally rise much too high.
My questions:
What could be causing this fixed value?
Could the control unit be defective?
Other observations:
There is a noticeable draft at the air intake on the primary turbo side.
All vacuum actuators have been tested and are working.
The turbochargers have been professionally reconditioned.
The primary turbocharger flap is open approximately 14% at idle.
The secondary turbo flap shows 0% when idle and opens at around 2500 rpm – correct according to live data.
Now it's your turn – I'd appreciate any advice!
Post #726446 19th Oct 2025 12:06pm
RRfranz
Austria 2011 Range Rover Vogue TDV8 Santorini Black
Good day,
The actual values ​​from the mass air flow sensor with the ignition on (engine off) are also 12,960 g/hr for my 4.4TDV8. At idle speed, it's 52,920 g/hr. Can a gentleman share his measurements? Thanks!
Post #726878 26th Oct 2025 6:53am
LandyKendy
Hello everyone!
I wanted to share my current live data at operating temperature and engine idling - maybe someone will spot something unusual or can help me interpret it:
Air flow rate from MAF sensor – Bank 1: 98,650 g/h
Boost pressure actuator – Bank 1 – Controller output: 0%
Boost pressure actuator – Bank 1 – Desired position: 74.6%
Boost pressure actuator – Bank 1 – Measured position: 74.4%
Boost absolute pressure – Raw value: 1.036 bar
What surprises me is that the actuator aims for a position and achieves it quite accurately - but the controller output is at 0%.
Is that normal? Is there perhaps nothing being actively controlled when idling?
I'm curious if any of you can comment on this or have similar values.
Best regards,
Kendy
Post #726994 27th Oct 2025 5:59pm
