The main pressure control for the transmission is adjusted by the EDS 5 solenoid. This modulates the clutch pressures according to the torque being produced by the (standard) engine. The clutches are therefore clamped with a force proportional to the load that they are seeing.
My concern would be that, if your engine has been mapped and is now producing more torque than the calibration stored in the transmission controller, the clutches are operating on a lower factor of safety than they were designed for. Unless, of course, the tuning company also re-mapped the transmission controller?
There’s certainly no harm in draining and refilling with new Lifeguard Fluid 6 and replacing the sump pan/filter, as long as you use a genuine IDS Filtran part. You need to follow the procedure for setting the fluid level to the letter, though.
A good indication of the transmission’s health is to read the clutch adaptions (charge pressures and times) as these will tell you the health of the clutches, the rear stator bush and the solenoids.
Phil
