![]() | Home > Technical (L405) > Blind spot monitoring fault |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564
Which amber light? Mine shows a small dot at slow speeds all the time (I think it says the system is working but not active at that speed , but that changes to being off when driving normal speeds and the car icon appearing when it needs to. V8 or else ... |
| Ffos-y-ffin Member Since: 20 Dec 2024 Location: Aberaeron Posts: 21 |
The very same amber lights. There is no ambiguity possible as there are only two, one in each door mirror. As explained, mine now stay lit permanently [which includes at all speeds, to make it quite plain for you] apart from when the ignition is switched off. The car icon remains dark and I never saw that even when the system did work. Neither do I see such a symbol on my Defender’s mirror on which the blind spot warning works perfectly.
| sullivj Member Since: 19 Jun 2025 Location: Gatwick Posts: 69
I think it works off a radar sensor in the rear bumper, so check there for any obvious damage or loose connection.
| JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 269
I had a similar issue with a front sensor, to the extent I was about to claim on my extended warranty. I decided to utterly soak it in contact cleaner (it was flowing by the time I finished) and it’s been fine ever since. Maybe worth a try….. 2021 3.0 P400 Vogue
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 462
Here's the wsm topic showing the modules location (one each side), you really need to be reading dtc's before pulling the bumper off to try and understand the likely problem. https://www.fullfatrr.com/gallery/albums/u...LATION.pdf L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
| Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 240
This may be a long shot but does the vehicle have a towbar fitted? If so it may be a fault to the trailer socket making the vehicle think a trailer is connected - blind spot monitoring is disabled when a trailer is connected. |
There are no fault codes in the system |
I’ll have a poke around the trailer socket to see if it’s that. Thanks. I don’t think so, because I have not noticed any difference in the driving mode, the camera behaviour or anything out of the ordinary apart from the permanence of the blind spot warnings in the door mirrors. |
If the vehicle detects a trailer it also disables the rear fogs and rear parking sensors and I'm sure you'd have noticed if they weren't working, then again it would explain the lack of dtc's.
I’ll have a poke around these also to see if there’s anything loose. |
Only if it detected current on the indicator trailer circuit. |
Good point |
| All times are GMT |
