![]() | Home > General > coolant help please! |
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 ![]() ![]() ![]() |
i am low on coolant - my 4.2 s//c reminds of this everytime I turn on the ignition. I go over to Land Rover dealer to buy more coolant but they don't have any stock of the pink stuff!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
the info's in our wiki.... |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
it is OAT and over here im sure its 50/50 mix but you might need to speak to the dealer to find out what mix yours needs to be.....also if you mix it with the blue stuff youll end up with a white sludge in your water system "RANGEISM WILL NOT BE TOLERATED"
thanks for the replies guys.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Coolant and antifreeze are the same thing. Coolant would be the general name but with antifreeze properties. The pink OAT coolant has anticorrosion stuff in it and is organic so can go down the drain. MOre expensive and ment to last longer than the blue. You cant mix blue and pink due to their chemical make up as they produce a goo thats bad! You can put any pink/red/orange in with yours or do a full drain and flush and replace with cheaper more avalible blue. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
As far as I remember American Marine Grand Banks motor yachts are made in Malaysia-Singapore and they will use it in there engines so it won't poison the water system in case of leaks. Should have it in vast quantities . 2008 MY Supercharged
