Home > Maintenance & Mods (L322) > How do test non return valve in remote oil filter housing ?
swast4
Hi,
Please could you help, I want to test that the non return valve is working in my remote oil housing. The reason being that I am getting the loud rattle/knock on start up after the car has been standing 6 hours plus. I have changed the non return valves behind the solenoids on the Vanos's. Before I go down the line of new Vanos's I have this niggle that the oil is draining out of the filter and this takes 2 or 3 seconds to get back.
So any ideas how to test ?
Thanks....................Adam
Post #73033 19th Jul 2011 10:16pm
Ad
Could you not remove it from block and get it on a bench to test? Looking on eBay there is a new one for £100 and looks straight forward enough. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #73037 19th Jul 2011 10:33pm
pretlove
im getting this as well so any help on what needs changing would be gratfull as i was going to just change the vanos "RANGEISM WILL NOT BE TOLERATED"
Post #73039 19th Jul 2011 10:38pm
pretlove
is this the part you mean
http://www.ebay.co.uk/itm/LAND-ROVER-VALVE...563209d59c "RANGEISM WILL NOT BE TOLERATED"
Post #73042 19th Jul 2011 10:40pm
Think thats on the vacum system that goes to the master break servo. Think Adam is after this http://www.ebay.co.uk/itm/Range-Rover-L322...646wt_1139 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #73046 19th Jul 2011 10:51pm
pretlove
do you reckon that could be the problem with mine then as it only does it once in a blue moon and its for a second at the most "RANGEISM WILL NOT BE TOLERATED"
Post #73060 19th Jul 2011 11:30pm
swast4
Thanks Rob for that spot, I have decided to buy that filter housing as had priced one up last week and it was 200 pounds so grabed that one while I could. The car is going in next week for rocker cover gaskets, oil change (Mobil 1 5-40)and the old filter housing is getting tested and changed if needed.
Pret, I will let you know my conclusions next week. If you are only getting it once in a blue moon I would be more tempted to change the non return valves behind the solenoids of the Vanos's and do regular oil changes with some good oil. The Vanos job is quite involved by all accounts and to me should be only concidered when you have tried the easy fixes.
Anyway, Ill let you know.
Adam
Post #73163 21st Jul 2011 12:14am
pretlove
thanks ill try that i dont suppose you have part numbers for that if not ill start hunting "RANGEISM WILL NOT BE TOLERATED"
Post #73172 21st Jul 2011 1:06am
swast4
Just thought I would report back on my progress with my Noisey start up rattle.
I bought a new complete oil housing complete with pipework, filter etc from ebay for 100 + 18 delivery (thanks Rob) and have bought 2 x 5L tubs of Mobil 1 from Costco and bought a bottle of engine flush from Toolstation for just undr 3 pound.
Went for drive to get engine oil hot, put RR in offroad position, switched off car, added flush, ran for 5 mins (not reving or driving it as per instructions. Then I stopped car, drained oil out and left it for hour or so to completly drain out.
I drilled out the broken rubber mounts that hold oil filter housing, which was a TW*T of a job, I really need to get lots of new drill bits.
Put everything back together and filled up with the Mobil 1, Jesus they drink alot of Oil, about 8 - 8.5 ltrs.
Started car up and I had initial 2 second rattle because oil lines and filter where empty, then I stopped car and checked level again and then restarted, with no rattle.
I started it again the next day and no rattle Smile
I then left it 2 days and started it again early in morning and no rattle (well very very slight noise for 0.001 second only because I am tuned into it) Wink Smile Thumbs Up
I started it again the next day and no noise - Sweet Bow down
So I am a very happy man, I think I still have some wear on my Vanos units but by having all the oil lines to my filter full of oil and a good quality thin oil in my car the top end of the engine and Vanos units get the oil pressure straight away.
When I get chance I will clean my old housing and test the NRV in work, but in the mean time I am happy if not still a bit nervous that it may return. Whistle
Adam
Post #75084 7th Aug 2011 12:24am
pretlove
well it looks as if this is what i need to do so thanks for the info Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #75139 7th Aug 2011 4:03pm
veyroncm
2011 Range Rover Autobiography Supercharged Santorini Black
We had this problem on a BMW and 2004 Range Rover and replacing the Timing Chain Tensioner solved it on both cars. Its a 30 minute job and the part is about £45.00 Can never part with old friends even though they cost me a fortune to maintain.
Post #76722 19th Aug 2011 12:15pm
dan_uk_1984
On my first 4.4 I found that if the oil level was anywhere other than at the top of the marker then I would get the rattle.
I also found that if I swapped to a slightly thinner grade oil in the winter months then the noise went away.
15,000 miles is a long time to spend on the same oil, and that's generally what the service interval indicator aims for. I change the oil twice a year, swapping grades and generally have had no issues on any 4.4 since doing this.
I wonder whether the oil change and flush you did would have cured the problem on their own?
Post #76723 19th Aug 2011 12:52pm
pretlove
dan what oil would you reckomend for this time of year "RANGEISM WILL NOT BE TOLERATED"
Post #76740 19th Aug 2011 4:18pm
dan_uk_1984
The normal grade - i just go for a slightly thinner grade in winter. You could go for a grade thicker in the summer too. Only if you have a problem with loosing oil (thicker doesnt leak out or pass piston rings)
If I ran winter grade oil in my P38 in the summer it would burn it... If I ran summer oil in winter it would clatter a lot. So i have generally followed the same principle with the L322...
Post #76752 19th Aug 2011 4:27pm
