Home > In Car Electronics (L322) > rear camera in a 2005 range rover hse
marbleweazel
United States 2005 Range Rover HSE 4.4 V8 Java Black
Is it possible to activate the rear camera input on the touch screen?
Post #73331 22nd Jul 2011 2:56am
3R10
France
technically it would be possible, albeit you would need a Faultmate to activate it. From what I've read, the problem is finding a camera (OEM one), if not, the other solution would be GVIF + Any other rear view camera. Feel free to correct me if I'm wrong! 2000 BMW M5, Avus Blue/LeMans Leather Interior
2006 Range Rover Westminster Java Black
Post #73336 22nd Jul 2011 7:58am
you need to switch it on in the CCF [car configuration file]..apparently dealers cant do it but autologic and faulmate can..
as you probably already know there are 3 inputs on the back of the screen ,one of which is a rear camera input..you can fit an aftermarket nstc camera and hopefully activate it giving you an additional reversing aid.. ..
Post #73343 22nd Jul 2011 8:46am
marbleweazel
found a local shop that has autologic......said he hasnt done it before. I am in the US and have the naviagation accept screen and no destination input while in motion. Can this also be fixed with the autologic?
Post #73462 23rd Jul 2011 4:21am
afaik you cant do anything about the 'acceptance' screen but the destination in motion can be done by a dealer so autologic should be able as well...
Post #73471 23rd Jul 2011 10:08am
marbleweazel
do i need any modules for the rear camera or just the camera and the autologic to activate it?
Post #73757 26th Jul 2011 6:15am
no modules just a 'smb ?' connector to go into the back of the screen and the camera/cable and of course the activation....
Post #73775 26th Jul 2011 9:46am
marbleweazel
okay got the camera installed in one of the rear lic plate lights. New question is there some type of resistor that i can place between the wires so i dont get the "check lic. plate light" nag?
Post #77322 23rd Aug 2011 10:19pm
you can get a resister of ebay or wire in a bulb......i gather the camera bulb is a led then..
Post #77324 23rd Aug 2011 10:21pm
marbleweazel
Well i removed the whole bulb assembely to make room for the camera. The camera doesnt have a light in it. Was hoping some knew the exact type of resister to put between the wires. Dont like the idea of a bulb in there because of the heat and possiblity of melting the wires.
Post #77335 23rd Aug 2011 10:40pm
.something like this will do the job http://www.ebay.co.uk/itm/2-Pcs-Gold-Tone-...5d2fa94ace
Post #77342 23rd Aug 2011 10:49pm
marbleweazel
ordered! thanks for the help
Post #77359 23rd Aug 2011 11:33pm
tolley
camera
https://vision-uk.co.uk/productPage.php?productId=145
might be handy
Post #78535 31st Aug 2011 7:26pm
need to measure up and confirm this will fit..as said on another thread the ad says its for a sport....
Post #78613 1st Sep 2011 10:05am
